The Young Effect, my gift to the free energy movement!
Started by captainpecan, November 16, 2008, 11:02:42 PM
allcanadian
innovation_station
can some one make me a little test...
you need a glass reed switch ...  a coil from a pulse motor   single wire is fine ...  a supply ...  and 1 cap
i want you to take mesurements... on input consumption   ....
you will note in this test you will see hemf at work ...... and learn to recover it .... on the INPUT SIDE.....    ;)
any takers.... i will draw a test  layout...  to follow ...
ist
if someone can do this test  ....  im trying to show you an important part here ....   and is nessary to understand the operation of ALL OF THIS
plus it is not showen in groundloops curcuit above...
allcanadian
@IS
What do you have in mind? I will build anything---once.LOL
Ok I see the problem in groundloops circuit, I wonder if were thinking the same thing?
innovation_station
here is the drawing
now i want you to test it without the cap across the reed  and see the bright flash of electricty inside the reed switch ...  i have burnt out many reeds learning this!!!!   my reeds are big too... they are rated at 4 amps.... the most i ever switched with thease reeds   was 15v 1amp and i burnt em plain out welded em inside the tube ....  ;D ;D :o
so there is no way in hell that was done from the inputed power!!!!!! lol ;)
any how what is the result on consumption of power  with the cap across the reed switch  i bet it is much less....  what is the consumption with out the cap
do the test  post results...
you will note the bright flash in the reed is hemf and the cap suckes it up.....  the cap loves this engery ....  choke coils do not ... lol
and this is how inductance fits....
ist
nightlife
allcanadian,
QuoteI find it quite false to say it was all worthless by any means.  There are some good points made no matter how it was tested. Many readers here had no idea you could even pass energy THROUGH a motor and use it again.
Now that I will agree with.  :)
