The Young Effect, my gift to the free energy movement!
Started by captainpecan, November 16, 2008, 11:02:42 PM
innovation_station
intresting to say the least ...
there is so much to learn ......   it is just wild....
well just picked up my 3rd amp so back to the bench to go at the 3 freq combo ....
lol
hey i also picked up 4 low pass crossovers tuned to 1.8mh @4ohms /350hz....  lamanited cores  my amps are 20w bridged 4ohm load
rotation as a biproduct anyone....
ist
time to assemble
i got 3 freq gennys too...   sine and square....
Gobaga
Quote from: TheBuzz on November 24, 2008, 11:46:13 AM
Post every free energy patent you can think of that uses a shorted coil in the process.
What appears to be the latest Hubbard coil:
http://www.rexresearch.com/barbat/barbat.htm
To my knowledge, the Hubbard coil has no shorted coils, but it has a spark gap (distributor) - the data on it is a little sparse.
What about devices that do nothave a shorted coil?
sparks
   @Pirate
          Yep.  And when the currents screw up because the sun's top plasma hemisphere is rotating one way and the other hemisphere the other (with a number of problems occuring at the hemispheric slip at the equator) we get mass coronal ejections. Sunspots where the plasma cant go anymore because the magnetic tunnel is still there stay around a long time too.
      I also believe that fusion is one process that is exoenergy going on but the main deal is emwave ordering that is so ordered that it leaves an energy vacuum of sorts.  Something like putting the entire vibrations comprising all of Earth's atoms into the aether occupied by one proton.   The escaping radiant energy is just a byproduct of this space densification or contraction.  Just a matter of time before everything lines up and poof goes the sun.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
wattsup
I had tried explaining this to @z.monkey in the Infinity Coil thread to use such a shorting system with his Hubbard Coil build. Something robust like a distributor would have been ideal. Here...
http://www.overunity.com/index.php?topic=5144.msg123027#msg123027
It is in fact very possible that such a "short then release" on a high induction coil would cause a compression and decompression, at which time the decompression happens faster then the actual matter can re-adjust, leaving a vacuum or internal "cavity".
Consider an inductor will spark when the connection is removed whereas a capacitor will spark when the connection is applied. Then there is the question of resonance.
All of this is pure Tesla.
AbbaRue
@TheBuzz
Do you think one could cause cavitation to take place inside a fluorescent tube, using the right frequency and a strong magnetic field?
I have noticed that sending high voltage DC pulses into a fluorescent tube cause dark rings to move through the tube.
You see these dark rings separating bars of light.
A very interesting observation.
