The Young Effect, my gift to the free energy movement!
Started by captainpecan, November 16, 2008, 11:02:42 PM
Groundloop
@innovation_station,
My goal today was to get this motor running. I can see that it is running ccw and that was NOT how I designed it.
So first I must reverse all three coils so the the motor gets the correct timing.
I also have BIG caps somewhere around here, found it, 10 FARAD 12,5 Volt. Will try that later. :-)
Groundloop.
captainpecan
Quote from: Groundloop on November 30, 2008, 03:11:26 PM
Now the motor is shuffling energy from the input, to the first capacitor, to the next capacitor and via last coil to ground.
The motor is using 0,05 Ampere at 10 Volt input. This is very close to my design goal.
Any guess on the rpms or power the motor is showing?  That photo you posted is a really bad angle I think, surely you have the reeds all in the proper placement.  The photo just makes it appear like the two back coils are almost touching each other while there is plenty of space from the next one.  Makes it look like the reeds are not quite lined up for the best performance.  I'm sure it's just the angle of the photo though, but I thought I'd ask.
Groundloop
@captainpecan,
Bad angle photo. There is a small difference in the placements of the coils.
Had to do that because of the available space on top of the plastic box.
I do not think it will impact the motor in a negative way. More important
is the rotation of the rotor. It is going the wrong way right now. I must
reverse the coils so that the motor runs clock wice instead. Then the position
of the reeds will be correct. Working on this right now....
Groundloop.
innovation_station
Pirate88179
@ IST:
Thank you for the explanation of the single reeds, now I see.
@ Groundloop:
Thank you also for explaining.  Nice job on your tri-coil set-up.  Is your 10F cap considered an ultra cap or super cap?  I was hoping someone would start messing with those on this topic.  I found some decent sources for reasonably priced super caps, some very high F too.  Best of luck to you on reversing your spin.  One thought, if it WANTS to spin that way, why reverse polarity to change it? It may, the way you have it set-up now, be more efficient in this direction.....just a thought.
