The Young Effect, my gift to the free energy movement!
Started by captainpecan, November 16, 2008, 11:02:42 PM
tinu
Quote from: sparks on November 27, 2008, 02:00:33 PM
   The newest cavitator the corporate owned scientists haven't got to yet.  Guarantee Keely's sympathetic vibrations cause a little cavitation and plasma.
                             http://uk.youtube.com/watch?v=ZxnEQssJ4FQ
Did you do your homeworks?
Or at least have you read some of the comments?
sunsarahgladys (1 month ago)
" if you ask im with your email he will ask you to send money to help them loll"
AlmostHydrogen (2 months ago)
"if you dont know if its real or fake, then why post something that could be fake?
perhaps before posting vids, you should make sure they are legit. Just a thot. "
That device is an utterly fake and it’s better not confusing and/or misinforming people around.
Ok?
Cheers,
Tinu
ramset
TINU the theory of how this COULD work is infantile
to call it a fake is irresponsible
yes Mr Thrapp should release this to the public
   Chet
Thanks Grandma
tinu
Quote from: ramset on November 27, 2008, 02:33:03 PM
   Chet
I regret but still consider now and ever that promoting a device before making sure it is legit is irresponsible.
Cheers,
Tinu
P.S. This thread has already reached its predicted 40 pages, which is much longer than I’ve expected.  ;)
I’m out. Good luck everyone!
sparks
   The thing Koen isn't getting is that you can magnify energy like when you use a magnifying glass to magnify the energy from the sun onto like your hand and start burning it.  The cavitation takes the chemical energy of that little shrimps muscle and magnifies a small portion of that energy into the collapse of the bubble.  The magnification of this energy causes effects on the mass not unlike the effect of burning your hand with the magnifying glass.  Light, chemical reactions, all sorts of shit going on when that bubble collapses that would not unless you magnify or time compress the reaction of the rest of the Universe into this small field.  Fuck fusion energy we got shrimp energy!  One thing about the boiler deal.  He probably should check his water for a ph change cause the heat is just one thing he rung out of the water mass.  You have hydroxides and hydrogen peroxides (which is a fuel) maybe a little hydrogen gas off the top. Transmutated carbon to iron if the water had any volatiles in them.  Beta radiation.  Nitrogen oxides from the combustion process.  ETC ETC ETC.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Koen1
Quote from: ramset on November 27, 2008, 01:43:15 PM
Koen  the 5000+ degree pulse the shrimp makes [Plasma] is not in the same league with prop cavitation
No, that is true, it is more in the league of the sonoluminescence experiments I mentioned.
Temperature-wise that is, because the mechanism does make use of physical displacement of the water
and that is not unlike prop cavitation.
But to give you some clearer links on the relationship between our sonoluminescence experiments
and the shrimps' cavitation "pistol action", I shall provide a link or two for your interest.
Now first of all the schwikipedia even has these factoids correct:
"The shrimp snaps a specialized claw shut to create a cavitation wave that generates acoustic pressures of up to 80 kPa at a distance of 4 cm from the claw. The pressure wave is strong enough to kill small fish.[7] It corresponds to a zero to peak pressure level of 218 decibels relative to one micropascal (dB re 1 μPa), equivalent to a zero to peak source level of 190 dB re 1 μPa at the standard reference distance of 1 m. Au and Banks measured peak to peak source levels between 185 and 190 dB re 1 μPa at 1 m, depending on the size of the claw.[8] Similar values are reported by Ferguson and Cleary.[9] The duration of the click is less than 1 millisecond.
The snap can also produce sonoluminescence from a collapsing cavitation bubble. As it collapses, the cavitation bubble reaches temperatures of over 5000 K.[10] The light is of lower intensity than the light produced by typical sonoluminescence and is not visible to the naked eye. It is most likely a by-product of the shock wave with no biological significance. However, it is the first known instance of an animal producing light by this effect." (from http://en.wikipedia.org/wiki/Pistol_shrimp)
And here's a little link to some sonoluminescence info: http://www.nature.com/nature/journal/v434/n7029/full/nature03361.html (Oh, sorry, I see one may only
read that article when registered... perhaps someone can find another version of the article?)
Here's some more info on "single bubble sonoluminescence", as these cavitation experiments are called, and their relation to plasma:
Let's start simple: http://en.wikipedia.org/wiki/Sonoluminescence
http://cat.inist.fr/?aModele=afficheN&cpsidt=16572452
http://www.ncbi.nlm.nih.gov/pubmed/16090812
http://www.scs.uiuc.edu/suslick/pdf/nature.030205.pdf
http://lib.bioinfo.pl/pmid:15744295
http://www.iop.org/EJ/abstract/1402-4896/72/1/012
And here's what schwikipedia has to say about "bubble fusion", which is obviously related: http://en.wikipedia.org/wiki/Bubble_fusion
In any case, my point is basically that the Pistol Shrimp uses sonically induced cavitation which is exactly what they're doing in the
luminescence (should actually read: localised plasma generation inside cavitationally generated microbubbles) experiments. The shrimp
uses its claw to produce the abrupt pressure wave in the water, a.k.a. sound.
Doesn't mean it's necessarily OU;
We can also produce very small localised zones of extreme energy density, but that doesn't mean we aren't inputting the energy.
I really think the shrimp inputs all the energy needed to make its claw snap shut, which provides all the energy for the sonic pressure
wave and this in turn causes the local cavitation of water which can sometimes result in very small and localised zones of such
energy density that momentary plasma flashes can sometimes be seen.
But yes, it is a cool trick for a shrimp, certainly! ;D
