Joule Thief
0 Members and 83 Guests are viewing this topic.
kooler
well i went to the foxhole for a couple of mins to make a small video
this isn't what i been doing but i figured i needed one more high voltage video before i moved to sumtun else
don't make fun of my messy table...
http://www.youtube.com/watch?v=OkLsbDaLjuk
till next time
Mk1
@all
I just found this !
How to connect multiple secondaries for bigger current !
gadgetmall
Quote from: Mk1 on December 12, 2009, 10:52:38 PM
@all
I just found this !
Mark how would you suggest we apply this . On one toroid or separate toroids ?
This  is good info. !
@Kooler . That rocks man  . One little battery ? you wont have any problem lighting up a couple dozen CFLs with that one .
Albert
xee2
@ kooler
Thanks for the video. It looks like your circuit is working well for only a 1.5 volt supply. If you are going on to other things perhaps you can post a schematic sometime before you forget what you did.
Mk1
Quote from: gadgetmall on December 12, 2009, 11:14:02 PM
ark how would you suggest we applythis . On one toroid or separate toroids ?
Albert
Well likely many cores , because you can load each of them , with out effecting the other.
But i may be wrong .
Page 78
http://books.google.it/books?id=0RmkmrFxHM0C&pg=PA71&lpg=PA71&dq=%22the+super+tube%22+Moray&source=bl&ots=0rOGUKlrkV&sig=6UA4S52QSjdElnDEXD4pXXqlYf0&hl=it&ei=0Y8fS4WqO4St4Qb5n_zfCg&sa=X&oi=book_result&ct=result&resnum=7&ved=0CCoQ6AEwBg#v=onepage&q=%22the%20super%20tube%22%20Moray&f=false
It takes some time to load .
