Joule Thief
0 Members and 141 Guests are viewing this topic.
innovation_station
Quote from: Mk1 on January 11, 2010, 04:36:11 AM
@all
I have put now a total of 3 secondary on my tp jt , i get about 1 volt a turn , so i have a 2 , 5 and 45 volts .
I have made this one also it gives 80 volts from 22 turns secondary , output outlined in yellow .
ok MK1 bro
we are gonna build it !
i have managed to clear off table 2 pull the hoh out ... and the mags genny   both are VERRY HIGH Q UALITY  tube driven units i will VIDEO IT  and share it ....
this is NOT MY HOH 808
this is a TPU!
I WILL GET A RING I WILL BUILD IT LARGE ....  i will tune it with the MAGS GEN and power it from the tube amp  ...  i MUST FIND IMPEADENCE  of the AMP FIRST
then i will winde a coil to match it or i will add resistors!  to match impeadance ...
then  I WANT TO CALL IT THE MK UNIT ..
here is your glue ...
H
I WILL SETUP THE LAPTOP METER....  i will scope it ...  i will tune it first ...  low volt then drive it with the amp ...
from batteries and an invertor ...
yikes ....
looks like i shall be busy ....
AGIN .  there 1000 ways to do this too!
but i like what aporch i have choosen .... ; )
innovation_station
this will consume   verry little engery ...  even pumping kw's ....
if you so desire ...  it will be luckey to use 110v 2 amp
all said and done ...
and then even more is said then done ....
W
care to build it mk1?
i will use 8ga thick wire rated 1000v 100a    good to -40
FOR MY COLLECTOR ... HOW BIG YOU WANNA MAKE IT ?
i have 16" 18" 24"  tubes   most likely more sizes ... i cant remember ..
i probally have 200 feet left of that wire ...  not sure ...
plus i have a full spool of 12 ga solid .. single strand ... 600v ... 40 amp at least ...
I WILL ROUND UP ALL NEEDED things to build
and i awaite any further  ideas sedjuestions   advancements you wish to add ...
its the MK BRO!     you call the shots! lol
do not FOR GET I  have the 1/4 megga watt high volt high freq rectifier ...  remember ... i told you all  they know where ALL thease have ever been sent ...
PEACE!
kooler
xee2
it is a regular jt
with a tip 31c
a cap across the resistor
and alot of resistance
it is a 1'' toroid goldmine
jeanna
Quote from: kooler on January 11, 2010, 06:08:44 PM
it is a regular jt
with a tip 31c
Kooler,
What is the value of the cap and the resistance, please, and since the vid is dark, how many turns on base, collector, and any secondary... please?
thank you,
@ all,
eesh I have tried 2 trigger coils so far and I have not been able to get jonnydavro's sec to fire up.
Has anybody had any luck here?
jeanna
xee2
@ kooler
xee2
it is a regular jt
with a tip 31c
and A of resistance
I think that is one for the record books. I have gottern down to 0.06 ma with the 3 transistor super JT but it stops working at a higher voltage than a regular JT and requires more parts. I think your regular JT is a better way to get low current performance.
Usually, it is possible to add more LEDs in series without decreasing the brightness of the first LED. Have you tried that yet?
