Joule Thief
xee2
Photo of the 15T-150T toroid used in the above circuit. Wire is #26 solid.
altrez
Quote from: xee2 on March 10, 2010, 08:48:35 PM
I think you need to explain a bit more. Magic what?
The lights get real bright and the multimeter takes a nap. I am not sure how I got it to happen. Also if I add a POT to the other coil I can make the led get even brighter but it has to be on a pick up coil to work, the POT that is?
So for example I am running the JT its powering the lamp. I add a second 100k pot to the current 1ohm pot. I adjust each in a sweep fashion.
Very perplexing.
-Altrez
kooler
xee2
the k1zm-slayer007 toroid circuit.. is the same one i use on 4 post inverters..
but some loads will lock the transistor down..
but it does output more voltage at the same input ma's (alot ma's )
robbie
xee2
Quote from: altrez on March 10, 2010, 08:56:48 PM
The A get real bright and the multimeter takes a nap. I am not sure how I got it to happen. Also if I add a POT to the other coil I can make the led get even brighter but it has to be on a pick up coil to work, the POT that is?
Very perplexing.
-Altrez
I am not sure what is happening in your circuit. But, when a circuit goes into resonance, the voltage across a parallel resonator spikes. That may be what is happening.
altrez
@all
I think there is some odd what I call "reverse amplification" effect going on here. If you Jam a frequency on a pickup coil. That wave seems to resonate down into the bi-filer coil. I think that this could be timed to cause a major flux?-in the field thus if you added another receiver coil would yield excess energy.
Cant prove it yet but I wanted to at least share my theory of what I am seeing.
The battery that would normally drive then JT needs to be replaced with a cap and a blocking diode so you can see that there is "back-emf??" or something flowing back down in a reverse effect. If you remove the cap then you get a see-saw effect if you could add a timer you could what I call see-saw a charge back and forth and the circuit I "think" will run.
If nothing more this does to me at least prove that energy can 100% flow backwards in a JT if the correct load is placed on the pickup coil to at-least change the frequency.
-Altrez
