Joule Thief
MrMag
Quote from: innovation_station on March 22, 2010, 01:34:33 PM
ok i have been unable to recharge my aa's properly as i cant find the wall charger ..
IST, Thanks. That's the best line I've heard for a long time.
All the devices you have built and can't find the wall charger to charge your batteries.
Think about it, It's hilarious.
Thanx for the laugh, I really needed that. :)
WilbyInebriated
Quote from: MrMag on March 22, 2010, 04:56:56 PM
indeed :)
detrix42
Quote from: Mk1 on March 22, 2010, 03:28:23 PM
You may do that , but i can help ...
I also started a tread for it , feel free to ask questions.
http://www.overunity.com/index.php?topic=8878.0
@all
Hi everyone !
Mark
Hi Mark.  I will probably have lots of questions. But I am also reading your thread and that is also answering questions. I want to apply JT circuit or something like your winding idea to my Newman motor I am building.  Not sure how yet, but I need to focus on build my third one, so the question will come later.  Thanks for sharing your idea(s).
resonanceman
Quote from: detrix42 on March 22, 2010, 10:40:43 AM
I tried measuring the pins, but this transformer is a bit weird.  Pictures below:
but I am only getting like .1 to .2 ohms between the pins even between the first and last pin on the 6 pin side.
I am not sure what the big white coated wire is exactly.
detrix
That looks like an interesting  coil
I am guessing that the white wire is high voltage.........
a fraction  of an ohm  would be about right  for the low voltage side......... some of he  coils I  have wired as JTs had at least one winding  with only 8 turns.
CHeck  for continuity between the different  connection points.
If you  can  find  3 pins  that  all  have continuity  you probably have  a winding with a center tap ...... This can be used  as your JT  primarys.
I  am guessing that the side  with  3 pins is the high  voltage side........check  these for continuity  with the white wire.
If  you have  continuity with one or more of them ........and  the resistance is  quite a bit higher than the other  side........you have a secondary .
If that is  high  voltage insulation on the white wire ...... and you start  with 12 V  I am betting you will get over 1000V out.......
Using  12 V I have got  250 V out of a small transformer with no  secondary
gary
innovation_station
lol
this little cridder works KICK ASS!
and the charge remains in my rechargeables ..  i have recharged bout 5 of em now ...  still useing the dead battery to run it ..
i found to just leave it with out pulseing it works well too!
W
i wonder if non rechargeables will work for translators? if they do may be able to get around the super caps to catch the good stuff!
