Joule Thief
0 Members and 149 Guests are viewing this topic.
Eastov
ist,
Dead batteries, BEMF, and spikes; is
there some way to measure for overunity?
e
innovation_station
Quote from: Eastov on March 25, 2010, 10:33:34 AM
ist,
e
i think the easyest way to acheive ou is to use a unit such as i  have just built .. as a power source for a pulsed application like newman or bedini or any other motor unit ..   recover from the SECOND STAGE UNIT ..
but you can also go LOW VALUE CAP  as output and BANG A SINGLE COIL WITH A FET .. AND FREQ GENNY ..
THEN LITE A 7 - 60W FILIMENT ..
xee#2   has practice ...
W
i also know if you go dubble banger on the drive coil .. it flys in speed ..  so then you have no trouble to fill caps ..  100 times the speed ..
i know slayer007 has done this  quite some time ago ..   wether he filled caps or not im not sure ...
and if you need undeniable PROOF MY WORK IS REAL TRUE AND  GIVEN FREE OF CHARGE ..
ALL IS ONLY AVABIL ON overunity.com ..
now charge a large value cap  to 30vdc use a pwm add MY NEO ZAP AND BE CAREFULL!
THAT IS YOUR WARNING !
W
now throw a cupple pancakes togather in 1 ring a standard pancake and a torous high freq.. : )
smak it with the neo zap plasma flash ...  it lites a 60 watt good n bright ..   this is the supply ...
for a TPU!
AC HAS ATAINED GOOD RESULTS FROM  24VDC 1 AMP ...
http://www.youtube.com/watch?v=SvleOLh42uw
http://www.youtube.com/watch?v=tGT5PB733a0&NR=1
lol
http://www.youtube.com/watch?v=r0etbntkxbs
Eastov
deleted, post error
resonanceman
Quote from: innovation_station on March 24, 2010, 03:19:27 PM
here is my newest unit
it is the entire system on 1 board ..
add a coil and battery holder your done ..
i have 2 caps 25vdc 4700 uf  1 per coil then joined as 1 feed
need a coil ?
ist!
IST
I was planning on  throwing together another battery charger  in the next day or 2.
I have a couple  questions  about yours
I see  3 chips on your  board........I am guessing  they  are  the JT transistor and 2 fast diodes.
Am I right  about this?
2 diodes would give an output  that pulses more than  a bridge.
On your  coil  what kind  of ratio do you have  between  the  primarys  and  secondary?
It is my observation that most people  on this thread   use as few  wraps  as possible for the primary.
I have started  making  coils  with larger  primarys  .......the theory is, start with  the biggest kick  you can .......
The  last  coil I made  I wrapped  3 cat5 pairs  as  a single wire
I did  12 wraps.
I wrapped  around in one direction
( 1 lap )
I see  that you often   wrap it in several laps.
Is there  an  performance  advantage to wrapping  in a number  of laps?
WIth the same wire  4 wraps  3 laps  would not be any harder to do
( I connected  2 of the pairs in series for my primary )
USing 12 V input  I got over 250 V from the 3rd winding
Swithing the coil  around  I go  380 V using the  single  winding as primary .......more voltage.......but I am thinking less kick ....... couldn't quite light  a CFL
gary
forest
Hello
Quick question : have you already found a charger which recharges its own power supply battery ?
Just asking  :D
