Joule Thief
0 Members and 81 Guests are viewing this topic.
Bizzy
Quote from: Mk1 on February 16, 2011, 07:27:22 AM
@all and Ground loop
I made a video of the Mk1 winding , based on Jeanna observation it transformed the radian tall spikes into something similar to AC waves , but benefit is to be able to load the secondary without losing power on the JT led .
Basically you wind one layer then come back winding the wire between the other wire so you have one layer thick on the top but 2 layer thick in the middle of the toroid .
http://www.youtube.com/user/abramrk1?feature=mhum
Thanks that will help alot
Bizzy
Pirate88179
Here is Lidmotor's Jeanna's Light schematic.  Maybe this will help also.  I built this and it works great.
Groundloop
Jeanna,
When you find the time, can you fill in the coil number of turns and wire thickness?
EDIT: Used the information from Bill in the drawing.
Thanks,
Alex.
Bizzy
Quote from: Groundloop on February 16, 2011, 09:04:38 AM
Jeanna,
Thanks,
Alex.
Hi Jeanna
Also could you give more detail on the 25R and 22 R. Also where were you able to find a torroid so large?
Thanks
Bizzy
Pirate88179
It was 3 turns on the base coil, 13 turns on the collector coil and 330 turns on the pick-up coil.  At least that is what Lidmotor had on his drawing that I replicated.  24 ga. on everything except 30 ga. for the 330 turns.  Transistor is a TIP 3055.  22 ohm base resistor and 25 ohm pot.  I actually added a second pot for better tuning.
http://www.youtube.com/watch?v=-m3sTtDbrPI
