Joule Thief
0 Members and 129 Guests are viewing this topic.
Thaelin
Xee2:
   Not sure if it will work in this setup but look at a zenier diode. They dont conduct until the rated voltage is reached. In this case it will reach it and dump and fall below again. Getting one for the voltage you need may be a pain. But then you might use a resistor in series with it to drop the voltage down.  Just that the spikes may cause havoc with it just not sure.
thaelin
Quote from: xee2 on June 11, 2009, 09:54:30 PM
@ Mk1
Thanks. I am going to need something like that soon. But this circuit continues to drain battery after it stops charging cap so someone has to switch off battery when neon comes on.
Mk1
@ Mk1
Well i don't see a problem there the circuit keeps the secondary alive .
But explain what you mean ?
Mark
electricme
@All,
I was reading up in a diode web site that there is a certain point where ordinary diodes will begin to loose performance at high voltages and very high hz, at AC for example when the cycle ends, the diode is still open, it hasnt shut fast enough, so when the next pulse comes through, some of the next pulse flows backwards before the diode can shut off.
So there seems to be a point when we will have to switch over to use high switching diodes.
This will give us all more pulse for the energy, at least it won't be waisted.
Got to do some more reading up on this first though.
jim
xee2
@ Mk1
Quote from: Mk1 on June 11, 2009, 11:32:11 PM
No problem, just needs watching.
jeanna
Quote from: Artic_Knight on June 11, 2009, 09:10:36 PM
now maybe someone can try to enlighten me but if the neos are not moving and thus not inducing a current then what the heck are they doing thats assisting in lighting a light?
Is it true that a magnet must be moving to conduct a current?
Anyway, even if that is true.
The assist happened when I added the magnet, which means it was moving.
The light went on as soon as it snapped into place.
I was then able to remove the magnet and the light remained on and as bright as before.
It makes me wonder how much lower the voltage could have been; or if the  combo voltage frequency could have been much different.
@Bill
@Gadget
@Jim,
thanks.
@All, I have a comment that belongs at the thread
http://www.overunity.com/index.php?board=13.0
It is about adding magnets to the earth.
jeanna
