Joule Thief
0 Members and 99 Guests are viewing this topic.
gadgetmall
Quote from: Mk1 on June 16, 2009, 08:44:27 PM
@all
Mobius !
@gadget
Tell us more about the one you made on a pole .
Hello Mk . Mine is the second one in the schematic using a mobius loop and then reversed in the middle . It is wound on a 1960's Am radio ferrite / barium? Rod . i never know what to do with it other than see the compass needle spin round when its drawn across the length of the coil so i wound a standard coil on top of it and used the mobius coil and the new standard coil to power a jt . It works very well on a 2n3055 transistor running as low as .5 volts . unsuspectingly for a silicon transistor i think . Actually i was looking for a interdeminisional spacetime torus portal device when i built it . and Just may be there is something to it . on a larger scale
. I 'll try it on 4 inch pvc on the next one . maybe 2 or 3 foot long ? What i want is 6.4 to 7.543 hertz coming  from this thing without any electronics . Don't know if its possible but some say it will. The wiccians do the drill spinning thing to make the wire bifialar before they make the mobius loop for their crystals and orginite generators . I do believe in orgone energy . i don't believe in any witchcraft as the wiccans do .I have seen chemtrails evaporate with a few large crystals i have in 4 corners of my yard and i have made orgone tower busters and chucked them near bad towers.Now that VHF AND UHF Singmals are banned on Tv they are up to something with those signals  , Its not because digital tv is better . BS. digital tv wont even work where i live unless  you put up a very high antenna. I got regular vhf tv with rabbit ears . you go figure why they mess up something that worked perfectly good for something that wont with out elaborate equipment . Next it will be radio frequency's going digital . watch and see .
the coil i made is here http://jnaudin.free.fr/html/tripole.htm its a mobius with a twist  . If you look close at the one i wound in mobius1.jpg there is a loop that reverses the field .
Gadget
TheNOP
Quote from: WilbyInebriated on June 17, 2009, 02:32:31 AM
you have a coil configuration that gets around lenz's law?
in part only.
those coils usualy use odd shaped wire, ex: flat side shaped wire, and spaces between each loops.
the thing is to make the loops mag fields to not interfere with each other.
but this might not be something good depending on what you want to do.
there are trade off doing it like that.
the_big_m_in_ok
Quote from: the_big_m_in_ok on June 16, 2009, 09:07:37 AM
TheNOP said:
No, but I'll show you what I mean: ...
>>Later re-edit:
What I exactly meant can be found on the wiring schematic as part of Reply #7310 on this topic thread Page 732, first post at the top of the page.  This involves the coil L3 and the 1000 uF caps on either side wired end-to-end with a diode in series on each.
The recovery method was what I patterned my previous circuit drawings from.
My next question is:
Can any number of either my drawings or something similar to the schematic on Reply #7310 be added to the circuit there without being affected by Lenz' Law limitations?
--Lee
TheNOP
Quote from: xee2 on June 17, 2009, 11:32:20 AM
@ Mk1
??? This diagram must be an April fools joke or something like that. It does not work! Just try it. When you put 50 volts across the wires in the center as shown you will measure 50 volts (NOT 100 VOLTS) across the other ends of the wires. This drawing is not real.
actually, that part is true.
but it goes like this: you put 100 volts on the ends and you will have 50 volts from each end to the middle.
it is simple Ohm's law voltage divider.
being bifilar or not will not change anything to this(DC).
half way in the coil = half the voltage.
xee2
@ TheNOP
Quote from: TheNOP on June 17, 2009, 01:44:02 PM
Not at DC. The only way this type of coil will double the voltage is if the input is either AC or very short duration pulsed DC (which has a lot of AC components in it).
