Joule Thief
0 Members and 102 Guests are viewing this topic.
Mk1
Quote from: Artic_Knight on June 18, 2009, 09:16:01 PM
MK1 as you are doing now what i recently have tried you will find that the tesla windings are a double edged sword.
if a tesla is doing the creating of a magnetic current then yes it is truely a stronger field!
however if a tesla winding is used as a pickup it will be like a step down transformer, converting to amps at a very very quick rate.
there is no doubt it can be very useful however!
i hope you find a configuration that i couldnt for using a bifiliar to bifiliar and bifiliar to regular i could not find a decent config that would greatly increase performance beyond maybe 50% reduction in consumption.
it did help though!
@Ak
Hi , don't worry if you mention something and don't get feedback, just mention it again and again. But i can tell you one thing i read everything , and got one of those good and quick memory stick.
I have tried the bi-tesla on pickup coil , i did not get the lower voltage , but it did not show any improvement , But using it one the jt side is different .
Mark
Mk1
Quote from: resonanceman on June 18, 2009, 09:47:11 PM
IST
How  are you suggesting  we power this ?
Just for kicks I wired up my mot  as a JT coil
On my mot there is  2 windings ......the low voltage winding is   much heavier wire than the high voltage winding ........there are only   2 connections to the low voltage .........3  to the high
The HV  has  2 white and one red .......it turns out that the red is  connected to the  core of the mot . .......
When   I  connected   the  HV  and LV coils together  with  a   jumper  then  hooked it up as  a normal JT    It fired right  up .
A cap in the tank seems to  make  it transfer more power .......
It must have very sharp spikes ........  with  a cap even  just  a .01 uf  my when  it is adjusted to make the array blink  I can hear  a snapping sound coming from my array
Correction    it  is coming from my  alligator clip
It is arcing
This  thing may  have  the  ability  to  recharge the battery  with no other  coils
With the Jesus charger    the  battery voltage rises   when I adjust the pot for low  draw
It  also seems to eat LEDs
I  notices some  of the LEDs in my array were VERY bright  the rest were either  very dim or not coming on at all .
Now after  running a while  none of them are coming on ........and  the LED on my JT board is  shot too .
gary
Why not use a triac and neon , 80 v pulse , chose the  cap for voltage or amp.
Mark
Pirate88179
Quote from: stprue on June 18, 2009, 03:32:38 PM
Thank you for your reply.  This is very similar to what I have been thinking about but only with a JT w/o secondaries.  I have 2 speaker inductor coils that I think I will need to play around with.  I am currently using the biggo coil and have good voltage coming from it, so now I need to re-change this voltage into something different!  Gary, do you think that striving for higher voltages is a good thing?  To me it does because the more voltage you can get out of a JT running of a AA the more voltage you can transform!
@ Pirate
Empty voltage!!!
What are your thoughts on this because to me and what I have seen in your experiments a maxcap/supercap/ultracap can put this so called empty voltage to preform work?
Well, you have all ready stated the reasons for my opinion.  When this issue came up either here, or on youtube, (or both) all I can say is that this "empty voltage" can be made to do work as I, and many others, have been able to do so.  My college physics professor said basically the same thing about "static" electricity not ever being able to perform work as it is static.  I have since proved him wrong to my satisfaction and then later saw Dr. Walter Lewin's (from MIT Physics Department) experiments which also prove my guy was incorrect.  Many forms of electricity can be captured in a cap (supercap or ultracap) and easily be made to do work.
Pirate88179
Quote from: altrez on June 18, 2009, 07:45:25 PM
I would love to have a free clean source of energy for my children as well. However I can not seem to find anyone who has accomplished this task as of now. There will be no free energy movement until we find a way to clearly provide a step by step document of a device that is simple to use provides more output then input and plaster the instructions all over the internet.
As of now I do not know of any such device. Please if I am wrong can someone point me in the right direction.
-Altrez
Try an earth battery, or 2 or 3.  This is totally free and clean energy.  All of the ones I have been working with so far are very, very small ones...but they still work.  if I had access to grant money, I could run my house from these alone, I am convinced of it.  Of course, I would also add solar and wind just because they are there, and I can sell the extra power back to the electric company at retail prices, which is the law here in Kentucky.  One could even make a power farm using all of these techniques and make a good living making free energy for folks.  It would all have to be scaled up of course, which I believe is totally possible from what I have observed in my experiments.
And yes, harnessing the power in a tornado would be very good as well.  That may be a few years off however, ha ha.
xee2
@ altrez
Quote from: altrez on June 18, 2009, 07:47:43 AM
So my question is simply this. Is there any real reason to keep pushing the voltage up? And if so why? What are you the experimenter trying to accomplish? What do you think will happen? I know I have a 900.000 volt stun gun and it will not light a 20 watt tube at full brightness so is the goal of this to try and hit millions of volts and if so what then?
The output voltage is a function of the load impedance as you will see if you use a 100 ohm resistor at the output of the pickup coil and measure the voltage across it.
