patent May 27 2008 -Haisch and Moddel- casimir
Started by froarty, November 24, 2008, 11:42:46 PM
froarty
patent may 27 2008 -close but does not mention the "secret" = molecular bonds must form while inside plates
Sent: Monday, November 24, 2008 5:52 PM
To: 'troarty@yahoo.com'
Cc: 'CaseyBlood@gmail.com'
Subject: patent may 27 2008 -close but does not mention the "secret" = molecular bonds must form while inside plates
Importance: High
United States Patent 7,379,286
http://www.calphysics.org/Patent.html
Haisch and Moddel
May 27, 2008
Quantum vacuum energy extraction
Abstract
A system is disclosed for converting energy from the electromagnetic quantum vacuum available at any point in the universe to usable energy in the form of heat, electricity, mechanical energy or other forms of power. By suppressing electromagnetic quantum vacuum energy at appropriate frequencies a change may be effected in the electron energy levels which will result in the emission or release of energy. Mode suppression of electromagnetic quantum vacuum radiation is known to take place in Casimir cavities. A Casimir cavity refers to any region in which electromagnetic modes are suppressed or restricted. When atoms enter into suitable micro Casimir cavities a decrease in the orbital energies of electrons in atoms will thus occur. Such energy will be captured in the claimed devices. Upon emergence form such micro Casimir cavities the atoms will be re-energized by the ambient electromagnetic quantum vacuum. In this way energy is extracted locally and replenished globally from and by the electromagnetic quantum vacuum. This process may be repeated an unlimited number of times. This process is also consistent with the conservation of energy in that all usable energy does come at the expense of the energy content of the electromagnetic quantum vacuum. Similar effects may be produced by acting upon molecular bonds. Devices are described in which gas is recycled through a multiplicity of Casimir cavities. The disclosed devices are scalable in size and energy output for applications ranging from replacements for small batteries to power plant sized generators of electricity.
Inventors: Haisch, Bernard (Redwood City, CA); Moddel, Garret (Boulder, CO)
Assignee: Jovion Corporation (Menlo Park, CA)
<a href="Patent7379286.pdf>pdf of Patent 7,379,286
Bernard,
            If I sounded strange on the phone it is because I have only slept 4 hours in the last 3 days! I need to sleep but I am so excited I cant â€" give me a call when you can at work till 3:30 = 856-722-4159 then home=609-267-4284 â€"my home email =froarty572@comcast.net
VR
Frank
________________________________________
Sent: Monday, November 24, 2008 2:18 PM
To: 'astro@calphysics.org'
Subject: FW: New Discovery! casimir plates bond hydrogen into hydrinos!
Sent: Monday, November 24, 2008 1:31 PM
To: 'sjp9x@Virginia.EDU'; 'jr7k@Virginia.EDU'; 'cas8m@Virginia.EDU'; 'ses5u@Virginia.EDU'; 'kdp2c@Virginia.EDU'; 'ccn4g@Virginia.EDU'; 'op6n@Virginia.EDU'; 'bss2d@Virginia.EDU'; 'rjt6b@Virginia.EDU'; 'hbt8r@Virginia.EDU'; 'hw@Virginia.EDU'; 'stt@Virginia.EDU'; 'dv3h@Virginia.EDU'; 'rcr8r@Virginia.EDU'; 'ses2r@Virginia.EDU'; 'kwilliams@Virginia.EDU'; 'mbw7a@Virginia.EDU'; 'dwilsdorf@embarqmail.com'; 'saw6b@Virginia.EDU'; 'jy2b@Virginia.EDU'; 'xz5y@Virginia.EDU'; 'nl8n@Virginia.EDU'; 'sl4y@Virginia.EDU'; 'pmf2r@Virginia.EDU'; 'bsd@Virginia.EDU'; 'cd4np@Virginia.EDU'; 'mf1i@Virginia.EDU'
Cc: 'ecd3m@Virginia.EDU'; 'physics.chair@vt.edu'
Subject: New Discovery! casimir plates bond hydrogen into hydrinos!
Hydrogen atoms bond into hydrinos when confined between plates!
Casmir effect allows relaxation of dimensional confinement and
method to form hydrino
11/19/08 | by froarty | Categories: energy
animaition moving plates http://www.byzipp.com/animation.htm
animation Casimir Force moving atoms
http://www.byzipp.com/animation2.htm
note: a certain portion of Casimir plates are formed in porous
cavities in the powder grains of skeletal catalysts like Rayney
nickel used in recent Rowan University confirmation of excess energy
by Black Light http://www.blacklightpower.com/ supplied material.
I propose that ZPE can be extracted using Casimir plates as
nanoscopic cavities where atomic hydrogen can form novel molecular
bonds while virtual particle density is low (only "small" virtual
particles AKA wavelengths of vacuum fluctuations can fit between
closely spaced plates). This same "low density" of virtual particles
reduces dimensional confinement. The Casimir theory proven to within
5% of predicted values in 2003 demonstrated unbraced metal plates
placed 2nm apart will be pushed together by the difference in
particle density outside the plates vs. the restricted density
inside. hydrogen atoms entering the plates will twist to spread out
in the 4th dimension but appear smaller from our perspective in
normal space. normally these atoms simply twist back into normal
space when they exit the plates and no one is the wiser. What Dr
Mills of BLACKLIGHT POWER claims to have accomplished is
create "hydrinos" that are sub zero state. he refuses to accept
quantum physics and has been unable to publish a paper accepted by
the mainstream community. My explanation is quantum based and so
intuitive that it only went unnoticed because the Casimir effect was
disregarded until 2003 and attempting to reverse the effect
electrically to produce something that could steer the virtual
particles doesn't work... Chemically However the effect can be
reversed by causing hydrogen atoms to form covalent molecules while
between the plates!
The "twisted" atoms form a "twisted" molecule that now
remains "twisted" after exiting the plates. these molecules prove
that our 3D world is a macroscopic illusion and that the sea of
virtual particles (Time) is actually a spatial direction like normal
space but only subatomic like electrons will normally permeate the
membrane surface partially. they are tethered to their atoms.
Now to harvest energy from these twisted inter dimensional hydrino
molecules...(or any other molecules you form while in dimensional
confinement)
the "sea" of virtual particles have no polarity but as Casimir
Polder suspected they determine lowest orbit of electrons thru
simple displacement. imagine picoscopic thumbs winking into and out
of existence getting between the electron and its never ending quest
to reach the proton in the atoms nucleus. The energy can not be
rectified in normal space because it is chaotic and averages to zero
BUT a "twisted" molecule that is partially submerged thru it's
covalent bond into the sea will force the normally chaotic virtual
particles to organize and do useful work to expel the "foreign
matter" back into normal space. the energy is stored after exiting
the plates in the covalent bond of the atoms resisting the organized
pressure of the virtual particles to force the molecule fully back
to the surface of normal space. you simply design a chemical
reaction that cuts the bond on the hydrino molecule and harvest the
heat produced when the atoms are "shoved" back into the "harvesting"
compound.
The real promise however is not free energy ... it is reactionless
drive - moving these hydrinos rapidly in plasma or ionized state
thru coils will provide reactionless propulsion for space craft.
the "tethered" electrons in a hydrio will pull their molecule deeper
into the spatial dimension of time. inertia dampening is also
possible by sweeping hydrinos around with ionized gas to form
whirlpools above and below your craft to form a partial containment
field like air inside an airplane cabin.
By coincidence porous catalyst such as nickel and platinum form
cavities that would contain a proportion of "braced" plates of a
geometry supporting casimir effect. maybe some of those cold fusion
pellets or Blacklights Nickel catalyst are already rectifying ZPE?
Excerpts from recent posts below were used for refinements above:
spatial dimensions are a macroscopic illusion! subatomic are free to
move thru the sea of virtual particles but Atoms must join together
to move the sea.... oh my GOD! moving the sea is TIME! keeping all
matter in normal space linked to "NOW" -Like a sieve being drug thru
water - If a little section of that sieve suddenly turned on
a "roarty-hydrino" drive it could pull the atoms of its little
section of the sieve into the sea (forcing open the pores AKA fabric
of space) -a "time craft" would appear to be shrinking away from an
observer in normal space as long as you are in front of the window
where it submerged but then would wink out of view once you pass the
window!
Frank Roarty
CSEDS Tech
856-722-4159
From: SocietyforClassicalPhysics@yahoogroups.com [mailto:SocietyforClassicalPhysics@yahoogroups.com] On Behalf Of Dr. Randell L. Mills
Sent: Monday, November 24, 2008 4:27 PM
To: SocietyforClassicalPhysics@yahoogroups.com
Subject: [SocietyforClassicalPhysics] Re: Na atom and H atom reactions
>--- In SocietyforClassicalPhysics@yahoogroups.com, "Dr. Randell L.
>Mills" <RMills@...> wrote:
>> >Dear BlackLightPower,
>> > I have a couple questions and would be pleased if you would answer
>> > them for me.
>> > The first question concerns the technical report BLP has released.
>> > I read the following and matched it to the graph:
>> > "The results of the DSC (100â€"750 °C) of NaHat a scan rate of 0.1
>> > degree/minute. A broad endothermic peak was observed at 350 °C to
>> > 420 °C which corresponded to 47 kJ/ moleand matches sodium hydride
>> > decomposition in this temperature range with a corresponding
>enthalpy of
>> > 57 kJ/ mole. A large exotherm was observed under conditions that
>form
>> > NaHcatalyst in the region 640 °C to 825 °C which corresponds to
>at least
>> > -354 kJ/ mole H2, greater than that of the most exothermic reaction
>> > possible for H, the -241.8 kJ/ mole H2 enthalpy of combustion of
>> > hydrogen."
>> > You say here that the exotherm happens under conditions that FORM
>> > the catalyst NaH. But if I understand your theory correctly it is
>> >the reaction
>> > of atomic hydrogen with atomic sodium that provides the excess
>energy.
>> > Those atomic constituents are created when the NaH decomposes,
>at the
>> > endothermic peak noted in the graph in the 350 deg C to 420 deg C.
>> > Would you please explain why the exotherm is happening at the
>640 deg C
>> > to 825 deg C, and not the lower NaH decomposition temperature.
>> NaH is a new approach to the catalyst reaction wherein molecular NaH
>> transitions directly to Na2+ and the hydrino intermediate H*(1/3)
>> that releases further energy to form H(1/3)
>> play the "Animation of the BlackLight Process" at
>> http://www.blacklightpower.com/process.shtml
>> > My second question is can an equibrium condition be established
>> >about the
>> > exotherm temperature where the NaH catalyst reacts, splitting and
>> >reforming
>> > continuously, without the reactor temperature dropping much below
>> >the desired
>> > steam generation temperature in the heat transfer cycle?
>> NaH is the desired species to propagate the hydrino reaction
>> > Sincerely,
>> > Robert Mockan
>> >Yahoo! Groups Links
>Dear Dr. Mills,
>thank you for your reply to my questions. I'm beginning to understand
>enough the reaction needs to be studied in more detail to determine
>the reaction coordinates that apply. Clearly once you have that
>information reaction conditions can be optimized.
>I came across some patent literature in my studies that would seem to
>indicate germanium may increase heat output, but I find several
>contradictions in the patent about the source of energy.
>Would you please comment about this? The patent can be viewed at:
>http://www.freepatentsonline.com/y2007/0263758.html
>and discusses experiments that appear to have been completed to cause
>nuclear fusion, rather than hydrogen collapse to the H 1/3 level.
>Could this be the fusion process you have mentioned in previous
>communications where the hydrogen collapse goes to completion and
>results in nuclear fusion?
>Sincerely,
>Robert Mockan
We are using hydrogen as opposed to deuterium in a chemical reaction.
The reaction proceeds at 80°C under standard reaction conditions. We
can identify the reactant and product hydrogen. If you have
questions regarding nuclear reactions under these type of conditions,
better to ask the cited authors how they can do this.
>Yahoo! Groups Links
__._,_.___
Messages in this topic (11) Reply (via web post) | Start a new topic
Messages
MARKETPLACE
From kitchen basics to easy recipes - join the Group from Kraft Foods
Change settings via the Web (Yahoo! ID required)
Change settings via email: Switch delivery to Daily Digest | Switch format to Traditional
Visit Your Group | Yahoo! Groups Terms of Use | Unsubscribe
Recent Activity
•    3
New Members
Visit Your Group
Yahoo! Finance
It's Now Personal
Guides, news,
advice & more.
Find helpful tips
for Moderators
on the Yahoo!
Groups team blog.
All-Bran
10 Day Challenge
Join the club and
feel the benefits.
__,_._,___
froarty
yes I want to test but need some skeletal catalyst - any easy sources come to mind? I am thinking hydrinos might reflect light in a VERY unique way... like out of normal space so it would appear to come to a point from our perspective
