ORMUS, the Vortex, and the Meyer/Bedini pulse
Started by krypt013, November 26, 2008, 07:48:29 PM
krypt013
by:  Jeremy VanHaitsma
   Lately I have been pondering the possible connections between various discoveries and technologies.  Take the stepped pulse signal used to make effective the free energy inventions of the late Stanley Meyer and John Bedini.  The way that the stepped pulse waveform steps down resembles to me in a way the nature of the fibonacci sequence, the vortex, the curving fractal curvature that seems to be so prevalent in nature.  In containers of ORMUS magnetic vortex trap water spontaneous vortexes have been seen to form out of nowhere.  Also during experiments of electromagnetically energized pyramids double helix type vortexes are shown to emit from the apex.  So here we have it, this vortex phenomenon appearing again and again in nature.  I wonder if anyone as of yet has made mathematical comparisons to the Bedini/Meyer's pulse and the Fibonacci sequence, or the Mendelbrot set, to see if there is some sort of fractal nature to the pulse that perhaps resonates with the zero point energy field by creating a vortex of some type.  I have seen other types of free energy type devices and systems that rely upon vortexes of some type for implosion, or centrifugal force, etc. ...  I am currently in the process of reading a book entitled "ORMUS: Myth, magic, & murder" and it is discussing how ORMUS could potentially be used to create stargates in the future do to its properties of being able to phase in and out of local spacetime?  Sounds pretty interesting and worth further investigation.
   Upon perusing through Stanley Meyer's patents related to his Water Fuel Cell technology I noticed that not only did he used the pulse SIGNAL as created by electronics to split water, like that used in the demonstration unit replications as done by Dave Lawton, Ravi Raju, and numerous other open source free energy researchers on the net and youtube, but that he was also able to use a laser beam shot into a resonant chamber to split water as well.  Keeping this in mind, and relating now to a previous document that I composed suggesting that perhaps the ORMUS material might potentially play a part in the workings of the Water Fuel Cell by acting as a catalyst working in concert with the SIGNAL and the ZPE field to cause the unconventional dissassociation of water.   Now, I would like to get into some crazy mad science type ideas and how they could be investigated as possible means of further investigating both the workings of these various fringe technologies such as ORMUS and the SIGNAL, but also shedding light on the nature of reality itself.  Let us refer now to the first experiments:
   ORMUS Laser - I have read that when the ORMUS material is subjected to extreme heat of 1000's of degrees that it can produce a golden colored glass like material.  This material is said to exhibit some of the unique "exotic matter" properties that are also possessed by the powdered ORMUS.  Such as temperature independent superconductivity, and some of the energetic phenomenon like the release of light/gamma radiation when too much energy is absorbed in it by the sun, etc. .  Anyway, for this experiment I suggest producing some of this ORMUS glass as a cylinder to use to make a laser with.  Now don't quote me on this, but I believe that the way of making a laser is to have a mirror on each end of the cylinder, usually a ruby but in this case ORMUS glass, one mirror being partially refractive while the other mirror is fully refractive, and surrounding the cylinder with a flashtube.  Then the light inside the cylinder bounces back and forth until it builds up enough energy to escape through the partially refractive mirror end.  So lets say that the Bedini/Meyer pulse SIGNAL was resonating with the ZPE field and that this is the same frequency or signal that resonates with ORMUS.  What if the flashtube surrounding the ORMUS glass was made to strobe in the SIGNAL pulse, similar to the laser that Meyer pulsed into the resonant chamber to split water with.  But the theory here would be to see if you could get some sort of extraordinary emission from the end of this unique type of laser since it is using an exotic matter material 'ormus' and a light signal modulated to resonate with the ZPE field.  I would also experiment with surrounding a cylinder of this glass like material with coils to see if it could be so stimulated by induction with the SIGNAL to exhibit different phenomenon.
   ORMUS Stargate - Ok, now referring back to the previous discussion of the mention of ORMUS possibly used to produce a stargate of sorts by the Annunaki or the anchients that were in the know, lets just suppose that it could be possible.  Two experiments that I would try to do to dig for further phenomenon regarding these technologies would be:
1)After constructing the ORMUS Laser supposing that it works, say one were to postion 3 of these lasers with the business ends pointing towards a central point.  The lasers would be mounted in such a way that the 3 beams would create a vortex, or a spiral which would be mathematically relative to the fibonacci/mendelbrot set, to try to interact with the vortex nature of the ZPE.  I suppose you could also try to borrow some of John Hutchison's findings since it appears that he has been able to get different types of matter such as metal and wood to meld together, float, produce antigravitational effects, and also produce some space time type anomalies.  So perhaps the extra ingredient of ormus could be thrown into the mix to see if some hybridized experiments could be produced which might shed yet even more light as to these things that we are working with yet don't fully understand yet.  Another experiment would be to produce a donut of this ORMUS glass material.  A toroid if you will.  Then wrap it with a coil and stimulate it with a pulse SIGNAL to see if you can get some sort of strange phenomenon, perhaps in the center of the donut.  Now with a conventional toroid electromagnet you would get a unique type of magnetic field flowing through the donut hole.  Perhaps you could get a similar energetic flow only with the etheric energy like that discussed by Barry Carter that ORMUS seems to exhibit?  Let us go now to the next experiment.
   ORMUS Capacitor - In Laurence gardner's book "Lost Secrets of the Sacred Ark" he talks about how the ark of the covenant might very well have been a type of large capacitor.  Given the way that it was construced using two layers of gold foil over wood being the dialectric I would suppose, and that it was filled with ORMUS.  The cubit dimensions of it were also important for some reason as the sarcophogas in the 'sweet spot' of the pyramid of giza was built with similar dimensions.  So perhaps the ORMUS was what charged the ark capacitor from the inside out via the ZPE field?  But given that that ark of the covenant and the pyramid sarcophogas both had ORMUS white powder associated with them, and the energy associations, I can't help but think of the contributions of Wilhelm Reich.  Wilhelm Reich was the discoverer of the ORGONE energy that he claimed was everywhere and was a type of life force energy.  Drawing alot of parallels to ORMUS which I believe is worth taking into consideration.  Anyway, he is known for his cloudbuster devices that can destroy chemtrails and make it rain more frequently, and he is also known for his ORGONE accumulators.  These ORGONE accumulator boxes draw alot of resemblance to the ark of the covenant except for the ORMUS of course.  And what better place to put an ORGONE accumulator than in the sweet spot of a pyramid since there has been so much strange phenomenon associated with that.  Like being able to make gold sweat monatomic oil, sharpening razor blades, healing people, and making plants grow faster.  Sounds like the pyramid is sort of an ORGONE focuser, and the sarcophogus was the ORGONE capacitor.  Barry Carter in his lectures discusses the stange etherically electric properties exhibited by the ORMUS and ORMUS laden water and talks about how the etheric sparks can jump 12" from you feet to a metal ground and display similar nature to static electricity.  It can also travel through a dozen people and back to a bottle of water charged with 'etheric' energy for lack of a better term.  Anyway, if the Meyer's bedini signal resonates with the ZPE field and that is partly responsible for where ORMUS is able to act as an intermediary to derive energy from, and the eqyptians knew of this energy and worked to harness and use it for whatever reasons via ORGONE type focusers and chargers, then lets try some experiements.  Construct a set of capacitors, one cylindrical and filled with powdered ORMUS and the other also cylindrical and composed of ORMUS glass.  On each end of the cylinder have some gold foild to have as electrodes, and using foil since it seems likely to resonate or be more in tune with ORMUS since it is of the same essence, and borrowing from the stories of the ark of the covenant to save time.  Now that we have our experimental ORMUS capacitor lets try charging it, with the Meyer/Bedini pulse, so see if we can get it to exhibit any anomylous phenomenon???
   So there you have it, some really strange and crazy ideas for potential experiments to try and help learn some more about the amazing properties of ORMUS, the PULSE SIGNAL, and nature itself to hopefully advance technological discovery and help mankind.  Not to mention having alot of fun in the process...  Have fun and happy reseach. ;D
