locating Steve Mark´s TPU demonstration house
Started by EMdevices, November 22, 2008, 09:00:43 PM
PhiScience
 Hi,
The earth is surrounded by a high voltage electric field.
This field extends from the ionosphere to the surface and the potential difference is between 300,000 and 400,000 volts.
The earth’s surface is negatively charged, the atmosphere is positively charged except in certain areas as in thunderstorms.
  The charge on the earth is generated and maintained by the action of high voltage atomic particles called cosmic rays and the action of short wave ultra-violet light emitted by the sun.
During solar flares the output of these rays can be tremendous and produce magnetic storms on the earth. The existence of this field has been known since 1752.
The positive field produces a voltage gradient across the atmosphere.
This gradient approaches 200 to 300 volts per meter near the surface of the earth.
This voltage can be as high as several thousand volts per meter depending on humidity, storms, etc.
  The total energy flowing to the earth at any given moment is 400,000 volts times the leakage current of 1800 amps or a total of 700,000,000 watts.
There are 300 thunderstorms going on at all times all over the earth.
It is believed that these storms maintain the equilibrium of the charge on the earth by maintaining the voltage difference.
  The Ark of the Covenant is described in Exodus 25: 10-21 as being a large box made of acacia wood and lined inside and out with a layer of pure gold.
The description of the Ark is of a very large electric. Capacitor.
If an Arc as described was built and placed in the earth’s electrostatic field and charged, it would have a charge of some 600 to 1000 volts and would have enough stored charge to kill anything that touched it.
  The Ark is supposed to have the power to kill, by some mysterious energy.
I believe it killed by an electric charge.
http://www.thunderbolts.info/tpod/2005/arch05/050302electric-earth.htm
http://www.crystalinks.com/earthsmagneticfield.html
The function of science is to make observations and measurements and to find correlations between the observed facts.
Gobaga
An electrical surge into a TV set will not pull the nails our of walls, much less twist them.
The Oregon Vortex is a gravitational anomoly - nothing is pulled towards it - nails are not puolled out of the buildings around the Oregon Vortex site.
The twisting of objects conatining iron, such as nails, is a big clue to what occured even if we do not understand it.  I think this requires very specific parameters.  No one has ever come forward to explain this, even with all the other explanations of SM's devices.
A rotating magnetic field?  This field would be several Tesla's to pull the nails out of walls.
A force that produced a rotation and attraction to iron would explain the naisl being twisted as they were pulled from the walls, but what force can do this?
Gobaga
OK
this is way out there
Rotating aether vortex patterned as a vacuum, electric field, and magnetic field - would have been inside the picture tube.
Pulled conductive objects toward its center and magnetic conductor were also twisted.  Might have only pulled objects in front of the TV, or more from in front and little from sides.
giantkiller
Quote from: Gobaga on November 25, 2008, 05:23:28 PM
The Hutchison effect.
I'll make you all a deal here. Everybody has an answer in the current thinking trends based upon their training or experience. Stuff it. I have continuously explained what the components are involved with what John has done. You can pull it right out of the videos. No magic. So forget what you think you know or can apply and investigate the Hutchison effect. The typical blather doesn't even come close. I even gave demos of multiple frequencies injected into Tesla's bucking coil. Albeit the power was small. But I saw what it is that everybody is chasing with their tongues.
The deal? I will leave and never come back. Seriously. One of you will catch on to high frequency heterodyning. Its not about me. It is about what is right in front of your faces. If you haven't built to experience then you don't know. I have not seen nor heard any comparative thinking based upon what I have stated here.. Everybody goes right into plagurizing or MSU(making sh!t up, yes that is the university you can't possibly graduate from).
--giantkiller. Clowns to the left, jokers to the right. Happy holiday in the tard rodeo.
Neolystic
Quote from: giantkiller on November 25, 2008, 06:00:17 PM
@GK, I agree with you that the imploding TV is likely the result of the Hutchison effect.  That being said, I also feel the need, as a friend, to tell you to stop with the freaking drama and abusive tone, it's not helpful here.  Besides, i don't believe anyone here wants to see you leave and never come back.
Now...what would cause this Hutchison effect?  If, in fact, all matter exists as a result of the omnidirectional heterodyning of the aether into single points of intersection which manifest as matter called electrons or other subatomic particles, THEN changing one or more of the component frequencies that comprise such intersections would have a direct effect on the makeup AND location of said matter.  Just my opinion.
- Neo
