Air Buoyancy Machine
Started by brian334, December 01, 2008, 05:50:29 PM
brian334
Please look at my video again. When a sealed cylinder is moved downward in water, an equal volume of water MUST BE LIFTED.
TinselKoala,
How much do my freefalling cylinders weight? Are you saying that something that is heaver than the liquid it displaces won’t sink?
No. Just as in my demonstration, I am saying that a "falling" cylinder must displace an equal volume of water--upward. There's no way around this. Look carefully at my video. Perhaps there will be an "Eureka! moment.
Buoyancy is a result of water, heavier than an object, falling under and thus lifting the object. The energy comes from the falling of the water. Thus, it is potential energy of a mass lifted in a gravitational field. There's nothing special, or even different, about buoyancy that could make it work in a gravity engine. You are still just lifting water and letting it fall back.
brian334
How much does water in water weight? The answer is nothing.
You lost me.
Obviously.
Try this:
Fill a basin with water. To the very top. Or draw a line at the top level of the water.
Now insert a hollow ball or pillbox like I did.
Push it right down into the water.
Did any overflow? Or did it go above your line?
So, you raised some water up by pushing the pillbottle down. This water WENT UP HIGHER than the original surface of the water.
It weighs what water weighs.
The difference between the weight of this water, DISPLACED UPWARD, and the weight of the pillbottle, is what we call "buoyancy." It is an effect of gravity. It is caused by the weight of the water displaced being heavier than the object displacing it.
Put some weights in the bottle so it is now heavier than water. Do the test again. Does the water rise up above your line? Yes, it still does. So by dropping the weighted bottle in the water, you are again RAISING an equal volume of water right up to the top of your basin, above the original level of the water before you dropped the bottle in.
brian334
O.K.
You try this, completely sink a tank and watch the water rise to your line. Than sink the same object a 100  more feet - how much will the water rise above your line?
