Homopolar Generators (N-Machine) by Bruce de Palma
Started by dtaker, December 01, 2005, 02:55:54 AM
wings
Quote from: Hypercom on September 30, 2010, 05:09:55 AM
Hi
Remove the brush devices in a system of multiple disks and use only the axis of rotation, it would be a great innovation ...
If someone managed to solve the problem please post a diagram of principle to discuss with all the researchers ...
Homopolar Experiment. In this video you see a ammeter used as a tester, a voltmeter is actually Vdc 60ma. full scale (without SCHUNT ammeter). The magnetic configuration is neodymium NS><SN.
The rotation of the trunk of copper tube is made with a mini drill.
Hypercom.
http://www.youtube.com/watch?v=9u1IZStSkHk
see also
http://www.electrogravity.com/ABUnits_1/ABUnits_1.pdf
http://www.electrogravity.com/ProofConceptTest/ProofConceptTest.pdf
from
Faraday Brushless Concept
http://www.youtube.com/user/JEBAYLES#p/u/0/AWN1hZZDCJo
Hypercom
Thanks wings
Very interesting document, you need a little time to study ...
I wanted to ask you a question, in this video we see magnetic resonance (Marcos Dancing Magnets)... http://video.google.com/videoplay?docid=5540717206741162529
This physical phenomenon is somehow related to this testing? (Successful Brushless AC Power Extraction From The Faraday Acyclic Generator) ... (A resonance at 2Ï€ Hz and 8:00 Hz Occurs During testing. At the 2Ï€ Hz resonance, THE ENTIRE test bed and vibrates at 8:00 Hz, the balance magnets in figures 3 and 4 swing back and forth violently.)
Regards. Hypercom.
Hypercom
Hi
Is there anybody who has replicated this experiment?
What do you think? What is your thought?
A small power production A.C. could also be induced by differences of magnetization in the material of permanent magnets in turn, as in the case of multipole magnets.
Question: What happens if a magnetic disk with axially magnetized NS rotation in place, has no magnetic field evenly distributed?
It is said that the earth's magnetic field does not rotate with the planet, ok, as well as our neodymium magnets placed in rotation, but if there are abnormalities or differences of magnetization of the material, they certainly can occur in a coil placed in the immediate vicinity, then the AC induced, may be the result.
Hypercom
angryScientist
Here is a link to my old thread. (I had forgotten it was in the  Half Baked Ideas section)
It's only one page long but it has pictures.  ;D
http://www.overunity.com/index.php?topic=8333.msg209874#msg209874
Magluvin
Hey Angs
Very nice.  Have you tried it yet?   I had got to thinking and there may be an issue where the connections from the outer of 1 plat to the outer of the other, this area is riddled with south pole field, and very strong.. As in my idea to force the mags together and wrap them in wire would increase the voltage easily, but its got me thinking that the S field on the outer edge of the wheel may counteract the current flow.  The S poles dont just go away. lol
this is the pic I am referencing.  http://www.overunity.com/index.php?topic=8333.msg214497#msg214497
It will have yo be tried.
Mags
