i find this of interest and Spreads light on the issue!
Started by lltfdaniel1, December 10, 2005, 12:30:29 PM
lltfdaniel1
100% eff , dream on !
its ether under or over - unity.
http://www.cheniere.org/techpapers/Final%20Secret%20of%2015%20Feb%201994/index.html#OU%20CIRCUIT
Every Electrical Source of Potential Is Already a Free Energy Source
    We thus advance a revolutionary concept: all present power systems already utilize free energy source-antennas. However, the standard two-wire closed circuitry diabolically utilizes one-half the total free energy extracted by the source-antenna from the vacuum, to perform work inside the source-antenna to dissipate its dipolarity and hence to dissipate the source-antenna (i.e. the receiver) itself.
    The source already acts as a "dipolar antenna" to continually receive "scalar potential" current d/dl (massless displacement current) from the vacuum. [Ref 9] Previously scientists and engineers have simply ignored this special massless EM energy influx. For load-free (i.e., mass-current-free) conditions, (d/dl) is continually received from the vacuum by any dipole (i.e., by any dipolar source-as-an-antenna), and the flowing energy is continually exchanged back and forth between the vacuum and the dipole.
    This free energy exchange with the vacuum is also true of any two points in our circuit that possess an open-circuit voltage or potential difference between them. Two such points act as a dipole. Free energy dipolar antenna sources are everywhere; we just have to learn how to break the symmetry in their energy flux exchange with the vacuum, collect some of the freely flowing influx, and distribute that collected excess energy to an isolated load to separately power it.
    In other words, we simply have to implement circuitry that operates analogous to the standard heat pump cycle.
Figure 2. Why present electrical power systems have underunity operational efficiency.
Conventional 2-Wire Closed Circuit Operation
    In the conventional 2-wire system a load is added to the source-antenna, allowing circulation of electron current in a closed circuit through the load and then through the ground return line back to and through the dipolar source-antenna. The only useful reasons for this "closed circulation" of the electrons are (1) it is simple, easy, habitual, and accepted, (2) all our components, instruments, and methodologies are developed in accordance with this usage, (3) one uses the electrons as a working material fluid to receive, transport, and discharge excess EM energy, and (4) forcing the electrons back through the back emf reloads the spent electrons again with excess EM energy in the form of little 's (excess trapped energy density) upon each recycled electron.
    Some of the excess collected upon the electrons is expended in the load as useful work, but one half of the total is expended in driving the spent (without excess
    Consequently all conventional 2-wire circuits, which return all external electron-flow current loops back through the source, are always underunity devices, as is shown in Figure 2. Eerily these conventional sources are already free energy devices, which are unwittingly attached to circuitry specifically designed to utilize part of their freely received energy to deplete or destroy themselves, i.e., they are already open systems receiving free energy from the vacuum, but they are hooked up and designed in a suicidal manner so as to use at least half of that freely extracted energy to re-close the system and shut off the influx of free energy. Since at least some of the remaining half of the energy is lost in inefficiencies, frictional losses, etc., less than half the total free energy goes to the load. So there is always less useful work being done in the load than the destructive work being done inside the free-energy source-antenna to destroy it.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
So we could have an Unlimited computer processing power, Unlimited Ram, NO CPU FAN,Unlimited Hard drive space, Unlimited Electric.
Unlimited heat, unlimited No heat (cold).
UNLIMITED PROCESSER SPEED, (999999999999999999999999999999999 GHZ??????)
COME ON OUR CIRCUITS ARE UNDER UNITY!!
lltfdaniel1
lltfdaniel1
Would there be any need of Greed?
because greed cuts in when SOMETHING IS DEPRIVED At the beginning isnt it?
like Food causes war doesnt it?
you know there are Real solutions to the world today,
Which is only Found in Gods Book, the Bible.
lltfdaniel1
