Feedback To Source
Started by nievesoliveras, December 21, 2008, 11:28:28 AM
gadgetmall
The Circuit look complicated  :)  My last Circuit i was Dealing with a resistance of 61 ohms thru the two coils . I have found building the fan bedinis that two will feed back the other one had over 90 ohms resistance thru the coil . it maintained a feedback but eventually decreased the run battery. the other powersupply bedinies i build all had resistance of 30 ohms and lower they would not feed back so 61 is a number of ohms that will feed back on my circuit . you could try putting a varable resistor between the spot of connection to plus feed back and see if theres a sweet spot it would run and charge  ??  .Just a Thought ... the Neon will not be needed in your circuit as it could Blow something if you let the cap charge up like i did before i put the feedback on thus a big spark . I think you wont do that !!you have sensitive circuit there .
nievesoliveras
Quote from: gadgetmall on January 23, 2009, 12:32:20 PM
It is not that complicated, it is just the coil output directed to the positive of the 1.5v battery as on your circuit.
I will try to find the sweet spot with a varaible resistor and a 10ohm resistor as on your circuit.
Jesus
nievesoliveras
When I tried the circuit with a 12v battery. The motor never stopped, but the battery was drained slowly. No charging.
I will eliminate one neon bulb, the second one, and try with a resistor and a pot to get the sweet spot.
Jesus
nievesoliveras
The circuit terminated as it should look working to get the sweet spot.
Jesus
gadgetmall
that top diode should be in series with the positive primary to allow one direction only not to the cap ??
no its not that complicate it just the booster ur using my be blown by my mod as  it feedback high voltage and i didnt want you to burn it out .. . there need to be a way to isolate the primary battery from your converter . im thinking a diode and capacitor array .. just rambling on that thought ..
