Feedback To Source
Started by nievesoliveras, December 21, 2008, 11:28:28 AM
Pirate88179
@ Jesus:
You could bore out the center hole to a larger size, then fill it with a good fast drying epoxy and then re drill the hole in the center by carefully measuring across the diameter in several locations and drawing a fine line with a ruler across the diameter.  Where the lines all cross is the center.  Mark this with a small nail for a starter point and redrill the size you need in two or three steps, not all at once.  In other words, a small drill to establish the center, then a mid-sized drill to open it up and then the correct size drill for your shaft diameter.  I hope this helps.
nievesoliveras
Quote from: Pirate88179 on May 18, 2009, 12:00:18 PM
@ Jesus:
Thank you @pirate !
That was exactly what I was trying to do!
I have a small drill press that is used with a hand electric drill, but it does not have something to hold the commutator steady at the center in order to drill it straight through the center.
The problem being that it always get on the other side a little to one side or the other but never on the center.
Then if you get the center with a small drill bit, when you try to get the size needed it gets out of center again.
I know that I will do it eventually.
Jesus
Pirate88179
Jesus:
This is hard to do without the right equipment, trust me I know.  if you can find something that you can chuck your rotor into, like a large drill chuck or an adapter, and spin the piece being drilled, this will make the hole round and centered.  to do this you can place the drill bit in a vice and then hold the spinning commutator above it as straight as you can.  That looks like it might fit into a 3/" drill chuck.  This way, the hole will always be centered.  Warning, if you do this, sneak up on the size because any error in being off-center will just result in a larger hole than you wanted, but still round, and still centered.
nievesoliveras
Quote from: Pirate88179 on May 18, 2009, 04:36:03 PM
Jesus:
Thank you @pirate !
The difficult part is the 3" drill chuck.
Jesus
FluxAmps
some more usefull info on overunity
http://www.geocities.com/Area51/Shadowlands/9654/bearden/addition.html
tom bearden says this about it:
Every Electrical Source of Potential Is Already a Free Energy Source
We thus advance a revolutionary concept: all present power systems already utilize free energy source-antennas. However, the standard two-wire closed circuitry diabolically utilizes one-half the total free energy extracted by the source-antenna from the vacuum, to perform work inside the source-antenna to dissipate its dipolarity and hence to dissipate the source-antenna (i.e. the receiver) itself.
The source already acts as a "dipolar antenna" to continually receive "scalar potential" current d/dl (massless displacement current) from the vacuum. [Ref 9] Previously scientists and engineers have simply ignored this special massless EM energy influx. For load-free (i.e., mass-current-free) conditions, (d/dl) is continually received from the vacuum by any dipole (i.e., by any dipolar source-as-an-antenna), and the flowing energy is continually exchanged back and forth between the vacuum and the dipole.
This free energy exchange with the vacuum is also true of any two points in our circuit that possess an open-circuit voltage or potential difference between them. Two such points act as a dipole. Free energy dipolar antenna sources are everywhere; we just have to learn how to break the symmetry in their energy flux exchange with the vacuum, collect some of the freely flowing influx, and distribute that collected excess energy to an isolated load to separately power it.
In other words, we simply have to implement circuitry that operates analogous to the standard heat pump cycle.
http://en.wikipedia.org/wiki/Refrigeration_cycle
I'm trying to comprehend all this, anyone any ideas for circuits like that?
http://www.cheniere.org/
bottom of this page:
June 2000:
The source charge problemâ€"“the most difficult problem in classical and quantum electrodynamics”*â€"solved by Tom Bearden.
then - "click here for explanation"
Seems by this guy that every electrical device is overunity and we stupidly use our energy to kill the mechanism that receives energy from the vacuum.
For as far as I understand he says that you can copy the charge of the power battery endlessly every cycle in the right setup
and u use the copy of the power so to speak to power the device every cycle.
The trick seems to be to keep the power source and the working device separated in the right way, in a way that the power source gives his potential to the working device but not looses any of it's charge.
By using the right setup and materials, so the power source is cut loose after it gave over it's potential energy to the working device but before current really starts to flow.
By copying the power sources potential in the right way the power source won't lose anything of it's charge..
He says it's in principle even possible to make multiple copies of one power source every cycle and power even so many multiple devices with it, as long as we avoid using our power to close the gate to the vacuum...
Amazing stuff....
I recently found a very nice link with lot's of information
http://thepiratebay.org/torrent/4362954/Megacollection_-_Tom_Bearden_-_Complete_Works
with this link you can download a shitload of books and info on what we try to achieve here,
you need some torrent software for it though, it's word to install one for this(temporarely even)
It also contains a full .pdf version of tom bearden's 894 pages book - Energy from the vacuum - concepts and principles
Which as I understood is considered as the bible on this subject according to some people
plus lots and lots of other interresting stuff( over 200 .pdf files)
Think it's a musthave for your toolbox....
