Feedback To Source
Started by nievesoliveras, December 21, 2008, 11:28:28 AM
nievesoliveras
@all
The correct orientation of the mentioned LED in series is like so.
Jesus
gyulasun
Hello Jesus,
One observation on your above schematics:  if you could use more LEDs in series with the one you showed, then the output voltage could be maintained at a higher level so the rotor would not slow down as much as it does now with the one LED.
The explanation is that with the LED you actually make a direct feedback from the 12V output of the LT1073 to its own 1.5V source via a rectifier bridge diode (the one at the 1 o'clock position) and the LED. The forward voltage of one LED is 1.5 to 2 or higher, depending on their color, so in case of one LED it is a huge load for your LT circuit.
By using 3 or 4 LEDs in series, you could make this load much lighter, hence there could remain 10-11V at least for the Bedini circuit to push the rotor as usual.
(I still cannot say you get overunity with this but a better operation...)
rgds,  Gyula
nievesoliveras
Quote from: gyulasun on January 22, 2009, 07:31:48 AM
Hello Jesus,
rgds,  Gyula
Thank you @gyulasun!
I will try that after I make some changes to the schematic and post it to see if that is what you recommend.
Jesus
nievesoliveras
@gyulasun
I made the changes and made the tests. When I added three LEDs the motor kept its slowness. I then added a 2200uf cap and the motor accelerated a little bit. But it continues to be slow.
The charge does not improve. Maybe I am doing something wrong. A photo and a schematic is included. The battery is disconnected.
I had to put a contrast wall behind the LEDs in order to see them. That paper does nothing to help the circuit.
Jesus
nievesoliveras
By the way. I was making a test with the first circuit without any LED and I connected the coil output wire to the 1.5v battery and it did not stop the motor. I was so glad. Then because the motor had no speed I added the 2200uf cap and the motor sped up. It was marvelous. I was so happy.
Suddenly I notice that the coil output wire was connected one hole before the right connection hole, hence it was so fast and unstopable. Big desilusion.
A photo is included.
Jesus
