Feedback To Source
Started by nievesoliveras, December 21, 2008, 11:28:28 AM
Koen1
@Jesus:
Ok, I shall try to make it clear. It is actually quite simple, but here's a little picture.
It was ripped from a rough schematic, so it doesn't look very pretty. ;)
I have put the letters A,B,C and D in the pic for clarity.
Let's say the output wires are connected to the caps at points A and C.
Let's say the "negative energy" positive potential spike arrives at A.
Now that cap's secondary plate, B, will "feel" the positive potential
and it will accumulate negative potential in the form of electrons that
are pulled from the rectifier bridge. This causes that same number or electrons
to flow through the rectifier and this is a real electron flow and can
be used as such.
This will also cause the plate D to lose electrons, becoming positively charged
in respect to C, and C will accumulate electrons from the main circuit.
When the "negative energy" positive potential on plate A evaporates back
into spacetime, the electrons on plate B no longer "feel" the electrostatic
attraction, and "lose their grip" on the plate, they start to leave the plate
and flow back into the rectifier circuit.
With each "stroke" of this "electron pump", that is, with each positive potential spike,
electrons are "sucked into" plate B and when the positive spike has gone,
they are released again. This basically "pumps" the elecrons around the
DC circuit that consists of the rectifier bridge's positive and negative wire terminals.
It is basically identical to using normal (non-4D, not negative energy but rather the normal
absence of energy that is normal "holes") positive potential in such a pulsed capacitive
coupling with a rectifier bridge, the only real difference is the peculiar form of potential
that is "radiant energy" or "negative energy" or "Dirac sea holes".
Plus of course that, according to Bearden, just about every steep voltage gradient will
cause a brief moment in which the symmetry of space, time and energy is broken
and the negative energy pulse lags behind the positive energy pulse somewhat, just
long enough to be used to power such a rectifier bridge.
And that is then just extra output energy.
Sorry for the text again... Hope it is clear?
If not, you can always send me a pm with specific questions. :)
Kind regards,
Koen
nievesoliveras
@koen1
Can two number 104 ceramic capacitors be used?
Or the capacitors have to be with big capacitance and electrolitic?
Jesus
giantkiller
Quote from: nievesoliveras on February 24, 2009, 07:06:26 AM
@all
There is a problem with my 1.5v runner and it is that the circuit charges the batteries, but the batteries charged by it cannot be put to work. I mean if you want to run something with it the batteries fail and loose the voltage.
If you check them with a meter after the test, they have good voltage though.
That is why I am exploring with other circuits and with the magnetic loops.
If I can find the answer for my circuit problem, I will post it for everybody to benefit from it.
Jesus
Now that you have opened the door and peeked in you must enter the space which invites with open arms.
Not too many of us here have gotten the RE generation. This why those that have not built cannot say.
You now have what Tesla achieved and reported in numerious patents and fashions. Keep on pushin'.
The standard electronics and physics learning has an idea what this frontier holds but no idea as what the key of the RE from BEMF from Resonance holds.
I followed what Tesla's patent stated with standard learning. I had no idea the eruptions of energy that would spew from simple copper windings. I, at no time, looked at what Telsa did with trepidation, fear, misunderstanding or prejudice.
What you did was good. Use that talent that is your gift and excel. After I got what I didn't expect I then went on a new journey to search for answers that the standards have no clue about and that happens after the Eureka moment. Now you can look at the world with a different eye that not too many men see through.
For those who haven't built yet I encourage you to do so. Otherwise your bus ride stops just short of the finish line. Like here.
Take this escapade here and apply it to Timothy Trapp. His configuration is a variation of the Ionizer with a motor in it. Doesn't certain Tesla coils have a rotary spark gap? How's that for a treat?
Now ya'll can stop wadin' in the shallows and hit the white water.
--giantkiller. There are no failures. Only experiences. Make them great and hold them dearly.
nievesoliveras
Quote from: giantkiller on February 24, 2009, 04:11:38 PM
Thanks @giantkiller !
Those words are a little out of my league and difficult to understand, but comming from you, I know that it is something good.
Jesus
nievesoliveras
@all
You all know that my drive is the feedback to the source.
There is one diagram made by @thedaftman that he shares with everybody about a possible selfrunner.
Selfrunner means to me that it gives feedback to the source, so it belongs on this thread too.
I posted my version of it back on this thread pages. But this one looks better!!
Jesus
