Feedback To Source
Started by nievesoliveras, December 21, 2008, 11:28:28 AM
electricme
@Jesus,
Well well well, just look at what my humble suggestion some weeks ago about using 3 batteries has done, but tap into the center battery only would do.
Congradulations Jesus, you have earned this, I am just happy I thought of the series batts.
Why did I do this?
Well as I was thinking how to stop a higher voltage from being squashed into a smaller container, I didn't have a LM317 adjustable to use, the next best thing was to "sample" the battery power.
          |-------------- 36v dc in ---------------------|
                                    |       |--------------- 12v DC
                                    |---------------------  out
If you needed just 12v DC but the only voltage was 36 volt supplied, then feed the 36 volts into three 12v batteries connected in series, then "feed" off the battery pile.
As I showed in my drawing, it should be possible to do a similar thing using just 3 capacitors.
Ohhhh isnt it great when an idea has a happy ending he he ;D
Rock on bedini circuits
jim
People who succeed with the impossible are mocked by those who say it cannot be done.
nievesoliveras
Quote from: electricme on July 21, 2009, 09:20:33 AM
@Jesus,
Why did I do this?
jim
Thank you @electricme !
You are always welcome !
I will experiment to see if I can make the pulse motor to run just on capacitors. That would be great!
Jesus
powercat
congratulates on all the work so far
QuoteI will experiment to see if I can make the pulse motor to run just on capacitors. That would be great!
That would be truly amazing    [As i am suspicious of battery chemistry]
cat
When logic and proportion Have fallen
Go ask Alice When she's ten feet tall
nievesoliveras
Quote from: powercat on July 21, 2009, 11:17:14 AM
congratulates on all the work so far That would be truly amazing    [As i am suspicious of battery chemistry]
cat
Thank you @powercat !
Jesus
dllabarre
Jesus
I'd like to duplicate your set up.
What is the value of D1 and Q1 in your circuit "STEP 3"?
On your motor, what size wire and how many turns each did you use?
What diameter is the coil of your motor?
Thank you,
DonL
