Pulse DC 60 htz
Started by Artic_Knight, December 31, 2008, 06:49:17 PM
pese
Quote from: Artic_Knight on December 31, 2008, 10:55:17 PM
thats fantastic, youve been very helpful! thanks a bunch!
Use this:
(LIVE)-----[ 470k ]----[ 470k ]----[ 47k ]----(NEUTRAL/Ground)
Phase  120v         66 v          6v                  0volt
Think about this:
6 VAC have Sinus-top point at about 10Volts
If using instead 47k resistor an 47k variable resistor
(47k linear pot), you can vary the output .
Pese
Yucca
Quote from: pese on January 01, 2009, 06:17:45 AM
Use this:
Think about this:
Pese
Good point Pese, that would also give control over duty cycle. A really simple PWM circuit!
I suggested (live to neutral) instead of (live to ground) to prevent house circuit breaker from tripping, but at that high resistance it probably will not leak enough to ground to trip anyway.
Yucca.
jadaro2600
Just use the rectified AC / half wave rectification.
Or create a pulse circuit with the 555 timer and use a darlington pair or a transitor to open a channel up for a solenoid switch that supplies higher power.
