Cavitation: Is it the key to alternative energy?
Started by Grumpy, December 31, 2008, 08:49:22 PM
Grumpy
Quote from: TheBuzz on February 04, 2009, 02:36:19 AM
After a bit more reading it looks like I want IR LEDS and have them and will test both light sources after the UV test. I should be able to test for about anything with the cell. Still have to build the power supplies and driver circuits and will get that finished up tomorrow.
All those resistors on Meyers gas processor probably means there are a bunch of LED diodes or lasers like he claimed. The ionizer would account for the other set of wires. After looking at a better picture I am backing off the one way valve claim on the bottom. Looks more like an electrical connection since it is brass and threaded. There is a ground lug open and it probably goes to that. I'll post the rest of the photos on my site later.
You bulb idea puts out more than those diodes ever will.
Infrared might prove interesting.
On the gas processor, I see the brass threaded stud with no wire, the black wire with red sheath and a label looks like a HV wire - like for an igniter - this may be for the ionizing HV.  I'd guess that the other black and red wires are for the LEDs.
        -Frank Edwards
Grumpy
Quote from: TheBuzz on February 04, 2009, 06:36:31 PM
The wire size appears to be the same - only difference appears to be strain relief to me.
Had another look at the original Meyer VIC and think I have my head wrapped around that. It is a pulse compression modulator. Normally we modulate RF as AM or FM but this appears to modulate much like AM and FM combined. Not sure what to call it so a pulse compression modulator for now.
I see why on the Puharich patent the wire from the secondary is not connected. He appears to have been using capacitive inductance of the coil and there would have been multiple banks. Not surprisingly, Meyer appears to have just copied the Puharich process in his own way.
Shake the oxygen atom 7 times and on the 8th, ping it with the high voltage once the electrons are spaced out from the oscillation.
A mental picture:
If I had 8 magnetic pool balls sitting in a line (electrical polarization) then I rattled them a bit to space them out (VIC bank would coil)and then I hit the end ball with a Q-ball (The high voltage through the gas discharge tube - spark gap) the ball on the other end will fly off leaving the other 7 balls. The all I have to do is retrieve my Q-ball (electron extraction) and I have HHO.
Make sense?
Meyer just rolled out of his posh poolside lounge chair and spilled his cocktail.
VIC coil is now laid to rest.
        -Frank Edwards
ramset
Thanks Grandma
sparks
      Looks like they are going high tech on Buzz's implosion.  They are burning some special fuel (heavy water available most anywhere)  to get some helium out of the implosion.   They are using I'll be damned Grumpys pulsed energy.  Of course they make sure to make something radioactive enough to come under the control of the powers that be.  In fact they already have the output priced up.  Look at the people involved and tell me this tech isn't gonna go south.      Obama is talking windmills while the good ole boys are talking return on investment.  And that extra highspeed neutron couldn't fuse with another high speed neutron and get a little gamma going.  That would release more high speed neutrons and oh oh black hole.  On top of that what are we gonna do with all this helium gas anyway.
Lots of goodyear blimps and party ballons and kids running around with gerbal voices.     http://other.nrl.navy.mil/LaserFusionEnergy/index.html
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Doctor No
Quote from: TheBuzz on December 31, 2008, 11:29:22 PM
Here is my diatribe on cavitation:
WHAT TO HELL CAVITIES HAVE COMMON WITH FREE ENERGY?
YOU FIND CAVITIES ALSO IN TEETH, BUT YOU NEED LATER A DENTIST AND TO PAY FOR HIS WORK.
CAVITATION IS SECONDARY EFFECT, YOU NEED HER, BUT NEED STHG MORE EARLIER
I suppose it would begin with the assumption that all there is, is energy. If I had to make a guess, I suspect that half the energy in the universe is in the form of mass. Mass is energy that is compressed, spinning and polarized.
IT IS NO WONDER E=MC^2
Our universe is made of fractals and surely the reason that if you expand Mandelbrot's equation out to the size of the universe, you begin to see images of snow covered mountains, trees and other things we see everyday. If you truly want to know the shape of the universe, look in a mirror. Edgar Cayce and the law of probability should be required reading for anyone wanting a better understanding of the cosmos.
YOU ARE RIGHT
Free energy:
The term free energy creates a reaction with an educated person since it implies energy from nothing. This of course is impossible and silly and so the reaction is justified.
OF COURSE
A better term would be "economic free energy". Since a gallon of water contains the atomic energy equivalent, equal to the chemical equivalent of millions of barrels of oil, the gallon of water would represent economic free energy.
YOU NEED TO EXTRACT IT FROM WATER ONLY
The best term would be mass to atomic energy converter. Since all free energy devices do just that. Energy does not come from nothing - no exceptions.
FROM SHORTCUT:  BETWEEN MATTER AND ANTIMATTER
Zero Point:
Notice nowhere in that simple equation E=MC2 is there anything that represents aether or zero point? I am going to stick with my own experience and some of the best scientific minds on Earth. Of course there is a zero point and of course there is less than a zero point. It would be impossible to have a black hole without less than zero and so everything in between exists as well. It has nothing to to do with free energy.
Aether:
The aether field was measured and observed by Dayton Miller using light-beam interferometry in the early part of the 1900s to measure an Earth-entrained aether drift.
Many scientist assumed and wrote of the existence of the aether field which included Crookes, Lodge, Faraday, Michelson, Moorley, Miller, Tesla, Reich and even Einstein.
Einstein later denied the aether field and this is confirmed in a letter he wrote to Shankland thanking him for disproving Miller. In the letter Einstein acknowledged that the existence of the aether would invalidate special relativity.
MAYBE EINSTEIN LOST HIS OWN SOUL (OR SOLD IT, I^VE HEARD TO j. p. MORGAN)
Dayton Miller did 10,000 hours of observation of the aether on a mountain near Ashland Oregon. His observations concluded the field moves at 24.5 kilometers per hour across the planet, concentrated between -100 meters below the surface and +300 meters above the surface and departs the planet in the direction of the constellation Leo. It tends to flow around objects like mountains but also flows through them to some extent.
HOW STARS TRAVEL IN TIME AND HOW THIS WAS OBSERVED THROUGH RUSSIAN ASTRONOMER KOZYRYEV, PLEASE SEE: http://www.universalinternetlibrary.ru/book/potapov/5.shtml
CHAPTER 5.3 MYSTERIOUS TORSION FIELDS
My own thoughts on this are that given the fact that aether has been proven to come from space and return to space reveal that it is sourced by a larger body such as the solar system or the Milky Way Galaxy or perhaps any large body of mass. Daton Miller's experiments indicated that there was an aether drift that also flowed from the Sun.
Regardless of what the aether is, it can be said with relative certainty what it is not. Is is not a source of free energy. Mass to atomic energy conversion and the aether drift are two entirely two different subjects.
NO, YOU CAN USE MASS OF UNIVERSE TO MAKE SHORTCUT BETWEEN MATTER/ANTIMATTER AND TO REGULATE THIS PROCESS
    * Free energy devices can only do one thing - convert mass into the atomic energy contained within the mass and cavitation is required to accomplish that.
NOT ONLY, CAN DO MASS FROM AETHER
HAVE YOU NOT HEARD IN SCHOOL, HOW AFTER REACTION BETWEEN MAN AND FEMALE CHILD CAN BE BORN?
    * Plasma is not a state of matter, it is matter in a state of change due to the fact that it is a cavitation.
PLASMA IS IN STATE BETWEEN MASS AND ENERGY, SUCH AS ELECTRICAL FLOW-IT^S MINI PLASMA
