HUMAN ENERGY - FOOD
Started by frog, January 05, 2009, 01:57:54 PM
frog
JUST A SNIPPET:
Here are some tips for beginner vegetable gardeners, with help from Ball and Kirsten Akre, manager of the Kilbourn Park Organic Greenhouse in Chicago.
1. Don't get carried away. For many new vegetable gardeners, "it's first love," Ball says, and they plant more than they can handle. It's best to start modestly with some of the easier vegetables: lettuce, radishes, beets, carrots, potatoes, summer squash. Though tomatoes are almost irresistible, they are not the easiest plant in the patch, so it's wise not to take on too many.
2. Weed and mulch. It's better to remove weeds by the roots rather than chopping them up with a tiller or cultivator, Akre says; many can resprout from the chopped-up bits. Get ahead of weeds early in the season and keep them from returning in force with a layer of organic mulch, such as straw, dried leaves or compost. Don't use wood chips, Akre says; as they break down they can compete with plants' roots for nutrients. Get a compost pile started and be ready to collect leaves this fall so next year you'll have plenty of free mulch.
3. Water steadily. Swinging between wet and dry can lead to problems, such as cracking and blossom-end rot in tomatoes, so try to stick to a consistent schedule, ideally watering in the morning. Let soil dry out between waterings, so roots don't rot and because stretching to get moisture makes them long and strong. Mulch will help keep soil moisture steady. Water more often in hot weather or when growing in containers, which dry out fast. Apply water low, at the soil level, rather than spraying leaves. Wet leaves attract disease. Avoid working the garden immediately after it has rained so you don't compact wet soil or spread disease between wet leaves.
4. Go easy on the fertilizer. It's tempting to try to push for big fruit or large yields by using lots of fertilizer, but that can burn the plants. Slow-release fertilizers, especially organic ones, are safest. If you dug plenty of organic matter, such as compost, into the soil when you planted, you rarely will need added fertilizer, Akre says.
5. Seek support. Many vining vegetables, such as peas, pole beans, cucumbers and tomatoes, need support to get up in the sunlight and keep fruit off the ground as it ripens. Check the seed packet for directions and follow them. Make your supports sturdy; ripe beefsteak tomatoes or other large fruits can really drag a plant down.
"When you change the way you look
at things, the things you look at change."
frog
frog
Starting Vegetable Garden Seeds & Plants Indoors by David Selman
http://www.gardenstew.com/about152.html
frog
frog
Once soil is completely thawed and no longer soaked with water, you can begin planting early crops: spinach, lettuce, peas, and cabbage. You can sow seeds for root crops like carrots or beets.
