Hydroxy from Cavitation
Started by Dave45, January 06, 2009, 07:44:50 PM
Dave45
Vacuum damn you just burst my bubble (Pun) but Im kinda thick skinned I'll have to check it out.  ;D
Dave45
Ok can we fill this vacuum with gas by applying a positive charge to the water pipe and a negetive charge to the hydrofoils hmmm but then the propeller moving the water would cavitate because of the bubbles in the water.
But would this stress on the water cause more hydroxy output? If the bubble in cavitation is a vacuum it must put one hell of a stress on the water molecule.
sm0ky2
the cavitation produced by a propeller or by the (holey rotor) is a compression/expansion of gasses trapped in the fluid. generally this is "air" or mostly nitrogen, with small ammounts of other gasses mixed in, O2,CO2, ect.
cavitation caused by vibration or sonic disruption is an entirey different story.
it is caused by a micro-vacuum, which collapses between the 'peaks' of the imparted frequency.
several gasses emit light, similar to an active neon tube
heres an interesting application, they are claiming small-scale, controlled fusion.
http://www.lenr-canr.org/acrobat/StringhamRcavitationb.pdf
