HHO Efficentcy
Started by CrazyEwok, January 12, 2009, 11:03:35 PM
TheNOP
Quote from: CrazyEwok on January 13, 2009, 07:45:47 PM
Ok... Just trying to make this black and white... Your saying that if you have HHO and "atmosphere(for arguments sake we'll state atmosphere is Hydrogen in tiny amounts, Oxygen in moderate amount and Nitrogen in massive amounts)" only the oxygen and hydrogen will implode and generate enough heat to make the nitrogen expand more than the vacuum created from the implosion? Other than expanding the Nitrogen doesn't react in any other way?
I find that a little hard to swallow... Sorry
IMO the idea of small implosion of the hydrogen and oxygen creating a small amount of negative force is out weighed by the extra hydrogen and oxygen that mix with all the other elements in the mix creating more explosive reactions to out weigh the small amount of implosions. This would account for ICE engines being "flooded" by HHO. All that is happening is the amount of explosions is no longer outweighing the amount of implosions... Mind you you could explain it as there is not enough nitrogen to expand from the heat... this could only be proved by seeing if there amount of nitrogen that comes out the exhaust is the same as the amount that goes in over a set period of time... otherwise you will have other compounds that have nitrogen in them coming out the tail pipe...
Hmmmm well i don't have the equipment to prove nor deny either statement...
this is kinda hard for me to explain in simple words,
there are simply too many physicale reactions happening during the whole combustion process.
to have an implosion you need a perfect mix of hho.
and the end result, before condensation, will be steam, witch can be concider ed as a gas.
yes, theoretically, you will have less pressure then the atmospheric pressure in the end.
but again, look at what the NASA use for space shuttle liftoff...
witch give more usable energy, perfect mix of hho or hho + atmosphere ?
we won't know for sure until someone do the maths using all the physicale reactions happening during the combustion process of both.
but one thing i know for sure, you will need a completely different engine.
just think at the valve that would be sucked open by the implosion.
