How do you dissassemble a CFL...
Started by jadaro2600, January 14, 2009, 01:12:39 AM
erickdt
I wouldn't do it at all. I've heard that they have toxic levels of mercury in them which makes them hazardous to dispose of never mind "take apart".
Yucca
On the one I stripped I wrapped the tube in a dishcloth to protect cutting myself if it broke (it didn´t break).
Then used a junior hacksaw and slowly worked around the mid seam of the plastic case which appeared to be solvent glued together. I went real slow and stopped as soon as I saw I was through in one spot then rotated to do another spot.
I chose not to use a dremel prefering the slower, steadier and safer hacksaw.
After the plastic case was halved I was able to get in it enough to liberate the board and tube using snips.
jadaro2600
I think that sawing off the screw end might do the trick, I'm talking about the small twist bulbs with the self contained voltage boosters and starter caps btw.
I have no interest in releasing any gases or mercury for that matter - the point is to maintain the integrity of the chamber and disassemble the starter unit.
Raui
So you don't care for the driver circuit and also whats the CFL look like because some look different to others?
- Raui
If you only knew the magnificence of the 3, 6 and 9, then you would have a key to the universe. - Nikola Tesla
http://ou-research.blogspot.com/ (Feedback appreciated)
jadaro2600
Quote from: Raui on January 14, 2009, 09:01:43 PM
- Raui
I wish to reclaim all parts. The device: http://ace.imageg.net/graphics/product_images/p1760709dt.jpg
