My Steorn prediction
Started by PaulLowrance, January 16, 2009, 04:14:23 PM
PaulLowrance
I predict with 99.999% certainty that Steorn orbo is a legit "free energy" machine!!!  How Steorn is describing the Orbo functioning process is just far to close to my magnetic theory. Someone on another forum made a recent quote from Steorn -->
Excerpt:
"There is no stopping perpetual motion inventors. Expect to hear more of Sean McCarthy, of Steorn Ltd, who has an all-magnet motor in Dublin. He claims that when you travel around magnetic fields, starting and stopping at the same position, you gain a constant stream of clean energy."
Also Steorn has mentioned magnetic viscosity is required.
Anyone who has studied my magnetic theory, based on conventional math equations, of capturing ambient thermal energy by means of magnetic theory should get it. You can see my early years of magnetic research made public in 2005 at -->
http://peswiki.com/index.php/Directory:PaulL:Details
There you can see an animation. There are two secrets -->
1. Change in magnetic permeability. You need to know the details to understand the method, as described on my page.
2. Magnetic viscosity. I used to refer to this as magnetic lag.
The magnetic viscosity/lag is discussed in the other part of my magnetic research -->
http://energymover.googlepages.com/
I will also predict that Steorn will eventually perform sensitive enough temperature measurements to discover the magnetic material is cooling down.
Lets hope Steorn succeeds in somehow marketing "free energy."
Mark My Words!   ;D
Paul
PaulLowrance
Sean from Steorn has said in public that the conventional electromagnetic theory mathematics makes it very clear. I have been saying this since 2005. Given a half hour of a physicists time in person, I can show them the clear cut mathematics using conventional physics that clearly shows a gain of energy, and I can show them precisely where this energy comes from, and how it is captured. Although I'm presently working on diode arrays, I spent so many times going over the math time after time. It is so clear cut. It's too bad that Tom Schum persistently asked me to study his diode array, when I was just ~ two months away from building my first "free energy" machine based on my magnetic theory!  :'(
PL
ChileanOne
Hello Paul:
I am very intrigued to know how sensitive you think that the thermal measurements should be to demostrate that the energy comes from the environmental heat.
Could you enlighten me on this topic?
Liberty
"I will also predict that Steorn will eventually perform sensitive enough temperature measurements to discover the magnetic material is cooling down."
Very interesting and bold, but I would respectfully disagree that magnets operate thermally from common things that we already know about magnets and how they act.  I have found them to operate on an atomic basis.  Permanent magnets may increase strength slightly when temperature decreases.  This is probably a result of the 'pinning material' within the magnet holding the magnetic particles in place more solidly due to the temperature change and rigidity of pinning material.  Also if temperature change increased, magnets output should increase if they operated by thermal conversion means.  We know that if neo magnets are subjected to too high of a temperature (curie temperature), it releases the pinning material bond in the magnet that holds the magnetic particles in place, allowing the particles to attract to each other and form a near closed loop within the magnet, having the appearance of a demagnetized magnet externally.
I do admire your spirit to strive to find new answers and methods.  Please don't stop your work, as you may well find something that nobody else can find because they don't see it that way.
Liberty
"Converting Magnetic Force Into Motion"
Liberty Permanent Magnet Motor
PaulLowrance
Hi,
Thanks for comments, but I think a lot of people are misunderstanding this. This technology has nothing to do with obtaining such energy from a heated or cooled source. This is not about heating magnets, etc. All matter all the time contains ambient thermal energy. Perhaps this will save some typing time -->
Where does the "free energy" come from? -->
http://greenselfreliantenergy.com/forum/index.php?topic=173.0
Simplified outline of how it captures energy -->
http://greenselfreliantenergy.com/forum/index.php?topic=174.0
And my Free Energy designs based on such magnetic theories, which is clearly based on the mathematics of conventional physics -->
http://greenselfreliantenergy.com/forum/index.php?board=44.0
PL
