Building a UFO
Started by Halifax, January 17, 2009, 03:29:22 AM
z.monkey
Check out this link...
http://www.amazing1.com/grav.htm
This is the best collection of books that are available on line.  These guys have been around for decades.  I have bought and read many of these books, which all have volumes of very fascinating theories.  But, again none of them have complete plans...
There are a couple that cover TT Browns work exclusively...
I have read:
"Antigravity and the World Grid"
"Antigravity Handbook"
"Antigravity and the Unified Field"
"UFO's and Antigravity"
While all of these are good reference books, you have to buy them.  In each subsequent purchase  I made I was sure to have found the 'key" to antigravity, but after having read each book I found that I only had a small piece of the puzzle.  This was 15 years ago when I was buying books like this.  Today with the internet and e-books you can get a far greater amount of information for free.  This leads me to my final point...
What you seek is within, not out there...  Your spirit has all the information you will ever need.  You should redirect your search to connect with the universal intelligence available through your own spirit.  This in turn can connect you with the repository of all knowledge, the great universal mind.  Your mind can reach out an access anything that is known anywhere, and is the best research tool you could possibly own.  By first mastering yourself, making a solid connection with your spirit, and understanding the first source you will then be able to easily master any physical task, such as building a electrogravity ship...
OK, Mo Later...
Goodwill to All, for All is One!
plato
Here are a few design concepts I've worked on over the years which are mainly inspired by the Grangemouth and Falcon Lake UFO incident.  They both share similar characteristics which are not likely to be coincidence.
http://www.zamandayolculuk.com/cetinbal/ElectricUfo.htm
http://www.youtube.com/watch?v=xlbyLxctJcE
Power source is based on the liquid-plasma model of our sun and more information can be found at http://www.thesurfaceofthesun.com/ Please note, the design is incomplete and too expensive for my budget!
Power Reactor (Helium 3 is generated and burned in the transmutation process)
Directional Thrusters (Possibly Relativity Drives. No propellant.)
plato
Looks pretty good, so far. I think you've got certain details wrong, and it might be a while before I let my penguin fly in yours, but mine is about ready...
plato
TinselKoala, do you care to elaborate on what may be missing?
The basic idea behind its power generator is Helium3 fuel production(See Arata Cold fusion). There is a waveguide in the variable magnetron which guides the microwaves to a fixed point at the center. In this space is a solution of mainly sulfur, nickel, and deuterium (Same elements in the liquid-plasma sun model). Here is the process in a nutshell:
1. Microwaves excite and heats sulfur under pressure. (Raising deuterium's boiling point is under work)
2. Sulfur heats and bonds with nickel metal
3. Nickel absorbs deuterium and transmutates it into He3 under proper heat and pressure
4. He3 is ionized thereby forming a miniature "sun".
5. Resulting ionized gasses are used to power magnetrons, electrogravitic shell and instrumentation.
6. Waste is expelled and distributed through small round channels in the hull.
Note: waste exhaust is toxic. I believe Stephen Michalak in the Falcon Lake UFO case was exposed and suffered its effects.
I intend to make a small experimental reactor model about the size of 2 cups when funding goes through. As for creating an entire craft, that would take a multi-million dollar budget. Deuterium and saphire crystals don't come cheap.
