Hemp oil cures cancer and many other deseases
Started by hartiberlin, January 21, 2009, 04:44:56 PM
Cap-Z-ro
The link I provided above has all the information one needs.
Regards...
PYRODIN123321
I know you can extract the oils using butane lighter refills or a big tank of it....put the greenage in a piece of PVC pipe put caps on both ends drill a bunch of small holes in one of the caps and one hole on the other end to inject the butane...the butane comes as a boiling liquid so you need something to catch it with, i used a big jar with a hole in the lid big enough for the pipe to fit through and let gas butane out, after you do it a few times you will need to let the butane evaporate and you will be left with the concentrate and a bunch of greenage with very little value..... :o
Peace.
sierraloewe
Quote from: PYRODIN123321 on January 22, 2009, 09:40:09 AM
this describes the exact way i saw it done.  It worked very well but you need a lot of greenage.
Kator01
Hello Stfan,
you can buy Hemp-Oil in every "Naturkostladen" in Germany.
Best Quality is Rapunzel Hemp-Oil because all oils of this company are filled in the bottles using Argon-Gas for protection against oxidation.
http://www.naturkost.com/p-rapunzel-hanfoel-nativ-250ml.html
Kator01
Kator01,like I mentioned earlier there's a difference between hemp SEED oil (which is the one you're talking about) and hemp oil the one Stefan has brought up. Hemp seed oil contains pretty much 0% THC while hemp oil is very rich in THC.
