LaFonte Group Pseudo Solid Magnet Motor OU test, 3 videos on Youtube
Started by Butch LaFonte, January 22, 2009, 12:30:33 AM
Butch LaFonte
See attached drawings,
Thanks,
Butch LaFonte
Butch LaFonte
Quote from: sushimoto on January 26, 2009, 01:19:05 PM
<SNIP>
I wish, I could. Cordially. :'(
But unfortunately, I am in Germany. Where can I get these drilled Magnets?
Maybe it helps, if people work on the same proof-of-concept simultaneously?
How else can we participate on an international basis?
Which 3D Program are you using?
If you export the model as DXF or any other interchange-format we could
at least share ideas and possibly improvements "virtually digital"
best,
sushimoto
Sushimoto,
Those are not magnets, they are 1018 mild steel. I had them machined here in town.
The large bars are 1018 steel also and the two magnets are grade 48 NIB, 1" by 1 "
I will post exact dimensions of test fixture.
I will ask Nicolas what 3D program he is using.
Yes I think we can work through the web on this.
Thanks,
Butch LaFonte
sushimoto
just mild steel?
WOW, a good example of how important it is, to think and keep it simple.
At least, i was considering them of beeing ferrite.
damn,
DAMIT DAS MOEGLICHE ENTSTEHT, MUSS IMMER WIEDER DAS UNMOEGLICHE VERSUCHT WERDEN.
sparks
   If you look at a plain old dc motor we see that the armature conductors continually fall into a void in the magnetic field of the stator.  This magnetic void is created by the armature currents driven perpendicular to the field magnetic lines of force.  In the direction of rotation the magnetic field flux is cancelled while "behind" the conductor the magnetic field of force is strengthened.  For a magnetic drive motor simply create the magnetic field so that the armature current needs not to be commutated and reversed.   This would involve two polarized rings one set inside the other creating a uniform magnetic field inbetween the two rings.  This will require no commutation as the conductors will always be in the same plane of the field.     Into this cavity or slot between the two rings (just like an armature conductor resides perpendicular to the field winding)   insert a circular magnet polarized to mimic a conductor carrying 25amps attached to the rotor.  Insert as many as you want on the rotor extending into the gap between the two pm rings.  Watch it spin.  Don't tell anyone or the powers that be will send puppets like the SEC to mess with you.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
spinner
Quote from: Xaverius on January 25, 2009, 02:41:44 AM
@ All,
       These videos of this device are the real deal.  I personally have examined
this device in Butch's office at his home this afternoon.   During several attempts,
I achieved the same exact results as in the video.  What is needed now are
suitable mechanical couplings to convert the mechanical force into a usable
mechanical or electrical output.  Venture capitalists/Investors are needed to fully
develop this concept.  Nice work, Butch!
Hi, Xaverius!
It's good that you've examined mr. LaFonte's (/ his group) device "in vivo"...
However, the "one shot" concept is not enough to recognise a real "overunity".
This was understood more than a century ago..  Old stuff, kind of..?.
(Remember the "SMOT" concept?)  ;) It's almost 90 years old....
Do you people really understand the concept of "Energy" (and all what is happening during the "interchange")?... Or, repetitive / periodical functioning, or the point of "closing " the cycle?
Yes or No?
Mr. LaFonte?
Why is it always so difficult (impossible, maybe?) to "close the loop"?
"Ex nihilo nihil"
