LaFonte Group Pseudo Solid Magnet Motor OU test, 3 videos on Youtube
Started by Butch LaFonte, January 22, 2009, 12:30:33 AM
Butch LaFonte
Se attached sketch
Thanks,
Butch LaFonte
Butch LaFonte
Butch LaFonte
If you like you can use 3/8" thick steel for the rotors and 1/4" hardend steel shaft.
See attached drawing for additional fabrication details.
Thanks,
Butch LaFonte
Charlie_V
You know, the problem with this is going to be when the little tab things have a load on them.  If they become loaded, it will be difficult for them to line up according to the field and trying to push the next one will cause stiction.  Do not let one of the tabs rotate and you'll see what I mean.  In the video the tabs started out horizontal and aligned themselves vertically in the field.  You'll find that when the tab is not allowed to align vertically (such in the case of a strong load) it will require a strong force to push the tab through.  I don't think this setup will work because the alignment of the field and the pushing of the next tab are too coupled.
A true over unity setup will be a one way street - action without reaction.  I haven't figured out how to do this mechanically yet.  However, electromagnetically its very easy.
