Magnethos' Notes: Research and Theory on Energy Amplification
Started by Magnethos, January 27, 2009, 04:57:31 PM
Magnethos
I hope this info could be usefull to anyone. I will post here my research on free energy systems. I will only use this thread.
27 Jan 2009
#1 Negentropy and Negative Resistance
Magnethos
27 Jan 2009
#1 On Negentropy and Negative Resistance I
After reading and researching a bit about free energy science, I'm getting some clearly ideas that I want to share here. We know, we're confused about free energy science and I want to share a few knowledge to this community.
As you have read, this post is about Negentropy and Negative Resistance.
Someone of us have seen a video on youtube about energy amplification system. The video shows that we can get free energy if we know how to replicate an effect NNRE (Negentropy-Negative Resistance Effect). I don't know the name of that effect, but I will call it NNR effect. If we look for the definition of energy in orthodox books, we will find:
Energy: is the capacity to do work.  ???
That's totally false. Energy has the capacity to do work, because work is correctly defined as the dissipation (disordering;scattering) of energy (order). The scattering of energy is work. It is not energy! I.e., energy is not definable as its own scattering!
Look at this way: a man has the capacityu to catch fish. That is true, but it is not a definition, since a definition must in some sense be an identity.
So... What the f*ck is energy?
Energy and Potential: Energy is any ordering, either static or dynamic, in the virtual particle flux of vacuum. Potential is also any ordering, either static or dynamic, in the virtual particle flux of the vacuum.
Energy and information theory: Entropy
Entropy (in information theory) is a measure of the uncertainty associated with a random variable, which quantifies, in the sense of an expected value, the information contained in a message, usually in units such as bits. Some scientists say that energy is information. So, if we co-relate the terms energy and information we will understand Entropy, Negentropy and Information(energy).
When we talk about entropy, we're refering to the order or disorder of any information(energy). Entropy means the disorder, so a high entropy system means high DISordered information. Negentropy means Negative Entropy. If we know entropy means information disorder, negentropy is the opposite process that turns disorder into order. And we know energy means any ordering in the virtual particle flux of vacuum. So, Negentropy means energy making. Chaos turns into order and we get energy in usuable form.
Negative Resistance
In common systems, we use Positive resistance. That means that a resistance in a common circuit, scatters the energy in form of heat. Energy pass throught a resistance and energy(order) turns into a unusuable form(disorder), by the Joule Effect. Of course, energy cannot be created or destroyed, energy changes of form. That theory proves that energy turns from order to disorder. It changes of form. But... where it goes after we use it? My answer is: to the Quantum Vacuum. So, the scattering process means turn energy from a usuable (ordered) form to a unusuable (disordered) form, throught a process that release energy in form of heat when the energy finds a resistance.
We know energy can be scattered in form of heat (heat emission), but only few people know, energy can be scatterd in form of cold (heat absorption). You can see these effects if you look for Thermoelectric Effect or Seebeck Effect.
But... if we scatter the energy with a positive resistor and the energy goes to the Quantum Vacuum... Can we get energy from that source (quantum vacuum)? you know the answer: yes. Common circuits are designed to disorder the information(energy). But we can develop a circuit to re-order that chaotic information(energy), and turn unusuable energy into a usuable energy form throught a process called Negative Entropy (also known as Negentropy).
But... how?
Of course, if Positive resistors scatters the energy to the Quantum Vacuum, negative resistor will absorb energy from the Quantum Vacuum, turning the disordered Virtual Particles of the vacuum into a ordered physical particles that we can use, energy.
ltseung888
Instead of using quantum vacuum, I use electron motion energy.
We can lead-out electron motion energy to generate electricity or do useful work.
We can also change the electron motion energy into other forms,
The Law of conservation of energy is not violated.
The two concepts can be compared.
Magnethos
Very usefull info, Itseung. Try to explain more about your theory here. We can co-relate the 2 theories.
P.S: Entropy and Negentropy.
COP > 1 means overunity.
Zorro
