Panacea-BOCAF 2nd MRA replication -COP =8
Started by ashtweth_nihilisti, January 27, 2009, 08:16:43 PM
pese
Quote from: ashtweth_nihilisti on January 27, 2009, 08:16:43 PM
This one has got more info and data to support Norm and Joel's patent suppression case, as well as a nice COP of 8. If you are able to contribute to helping this situation please contact us.
http://video.google.com/videoplay?docid=-8020205776562649310&hl=en
Ash
@ash
i shown above video.
this say NOTHING,
yes this are possible 20ma LED (datasheet),
but this sax that 29mA that you can drive with.
give attention, they will light also with 4 to 5 mA very bright.
IF (and i think so) if it lightning with 4mA . you have no oberunity, you have still some losses.
So you cant say that are 5 time 20mA . to manipulating
an  4-times overunity.
You must test this (i you can di it).
It is normal that that PIEZO will transfer an resonancy frequency,
but this is not mysteriosly.So you can explain that .
P.S. its not an Condensor ! Is not workin in such function in this circuit
Gustav Pese
poynt99
Ash,
What was the frequency you found worked best with your setup?
Fixing the duty cycle won't be much of a problem, although I don't know if it would make that much difference anyway if it changed a few percent.
Sure, I'd be happy to design the circuit. Let me know what the fo frequency is and what range you want.
..99
ashtweth_nihilisti
Gustav, go get the same LEDS and signal Gen and light up 20 LEDS. I know your wrong, but i dont discuss this, read my prior posts.
Ash
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
ashtweth_nihilisti
Quote from: poynt99 on January 28, 2009, 10:38:10 PM
Ash,
..99
poynt99 , sure thing and thanks man, ill get the precise frequency for you and post tonight, will have to wait a few hours.
Ash
ashtweth_nihilisti
Hi poynt99 ,
Okay, the 20 LED circuit was operating at 16-17Khz on a square wave ( i would make the range 20-25Khz encase)
So what we really need is a variable frequency(to tune to resonance) and a fixed duty cycle of 50% - Can be Square wave
Andrew thinks this is the only way it will work. As even changing the leads length and plugging in another circuit, changes the resonant parameters, that's why it may be a higher freq or lower form the driver circuit after removing the signal Gen..(make a higher range please) this is one sensitive device.Joel and Norm have told me about how the moons gravity and Sun effect the out puts.
Ash
