HydroMeyers Vic
Started by Spewing, January 31, 2009, 03:02:14 AM
johnbostick
Quote from: TheBuzz on February 06, 2009, 01:22:19 AM
WTF? Calm down? I was calm until you said that. Now I'm going to get all medieval on your white ass.
The term is not medieval it's moron
Just because you don’t see it doesn’t mean it’s not real.
johnbostick
Quote from: TheBuzz on February 06, 2009, 12:08:52 AM
Here is a photo of all the parts. Where is that all important VIC transformer? It looks like it became part of the distributor and is now called a hybrid laser distributor.
Where is the tube cell? It became part of the air/gas processor and probably no longer exists because it was replaced with ionized air in a laser cavity and maybe... maybe a single cell but I doubt even that is in inside the air gas processor.
On the back of Meyer's early dune buggy you see a bunch of flat metal plates inside a metal box with a plastic see through lid. That is most likely the air / gas processor where ozone is being made. Meyer most likely later found that the laser helps remove electrons and that makes a much more nasty radical.
What I am sure of is this:
If you think you are going to wind up some resistive wire on that coil form and make a bunch of bubbles, you are completely clueless about how Meyer's process worked.
If you think hooking a fluorescent lamp ballast to a diode and a tube cell in a pepsie bottle is "restricting amp flow in a dead short condition" and some big secret to Meyer, do the world a favor and breath gun powder.
The kids playing with the water spark plug most likely got as close as anyone to replicating the rotary pulse generator mixing pulses of high voltage and hi current.
It produces a cavitation when the high voltage skin effect moves over the top of the water droplet and the electrons move toward the surface. The voltage breakdown then slams them back to the center and creates an atom cluster which explodes back out at near light speed due to coulombs law (like charges repel)  which produces electron cascade and a mass to energy conversion (fission)
Therein most likely lies the secret to the tube cell that people are so fixated on. Learn about the rotary pulse generator and look at the top center tube. You can see a clip holding something in there. A spark gap, a xenon tube, a small hydrogen laser, a mercury gas discharge tube - something along those lines.
I don't have to call you a moron read what you posted.
johnbostick
Quote from: TheBuzz on February 06, 2009, 01:59:10 AM
Ramset - Ask Hartman click on this trolls user name and then click "track user" and ask him to ban the user names and IP's. His purpose here is clear.
If they haven't banned you yet they surely wont ban me.
ramset
john
This is no time to play games
The Buzz is a serious experimenter with MUCH insight
Please  don't waste his time
I must say you do not seem to be aware of certain things that are relevant to  the Evolution of Meyers tech
Grumpy And the Buzz are
And they are sharing experiment results and TONS of useful information
It is a privilege to have these men here, and to know they are busting their Buts for open source is AMAZING
Please don't hinder this process
     Chet
Thanks Grandma
Grumpy
Buzz
Look at Meyer patents 4,798,661 and 5,149,407
Notice in the first that no chokes are used and the system operates from AC source and also Meyer exaplains the basic process quite clearly.
In the second patent, Meyer explains the use of the various processes to achieve the desired effect.   Many combinations of processes could be  mixed to achieve better results than individual processes.  Figure 9 shows the VIC with a M27 iron core.  The chokes were only 100 turns of 24g.  Later he gives an example with 26v at 10kHz.   He then explains that when resonance is achieve the flow of amps is "minimized" - thus this is not an electrical resonance.  Meyer also explains the cascading of multiple stages to increase the energy in the gas.  Bottom of column 10 mentions the use of a grid to extract electrons - I always wondered about that.
Every one of the processes mentioned is well known process for achieving the same result.  Meyer put them all together.  Meyer went through great pains to remove free electrons - further proof of the fission process that I previous presented.
EDIT:
Stan's pulse generator patent: 4613779
        -Frank Edwards
