HydroMeyers Vic
Started by Spewing, January 31, 2009, 03:02:14 AM
Goat
Quote from: Spewing on February 01, 2009, 03:07:55 PM
http://www.youtube.com/watch?v=uC53wdVtvPY
http://www.youtube.com/watch?v=hpsQ0QspCGw
http://www.youtube.com/watch?v=QBcJlEWlxvk
@ Spewing
In the last video link hydrocarz mentions in his video info that:
"Micro Vic Now Becoming History. Out with the old in with the new! Thanks for the torriod! Electrojolt saves the day! "
I am not current on all the latest developments but here goes, does the above mean that the old Vic coil wrap model has been replaced with a toroid form by Electrojolt?
Paul
TheNOP
Quote from: Spewing on January 31, 2009, 03:02:14 AM
How do you restrict amp flow and allow voltage to take over in a dead short condition,,, is it even possible ?
leakage transformer
"leakage transformer, also called a stray-field transformer, has a significantly higher leakage inductance than other transformers, sometimes increased by a magnetic bypass or shunt in its core between primary and secondary.
This provides a transformer with an inherent current limitation due to the loose coupling between its primary and the secondary windings.
The output and input currents are low enough to prevent thermal overload under all load conditions â€" even if the secondary is shorted."
Spewing
Quote from: TheNOP on February 01, 2009, 08:29:19 PM
leakage transformer
AHHHH,,,,, This is the post i was aiming for!
Guess i don't need to be hanging around here on these forums Showing you how its done since you seem to have it all figured out....
It took long enough, But i made the point i Intended to make when i started this thread.
Who else knows how to do this? Step on up here
watercellguy
I totaly agree with Hydro on this one.
My self, have contributed with maybe the best narrow band EFIE ever created and shared it, just to have others claim that it was them then did it.
The bottom line is: People Suck!!!!
