HydroMeyers Vic
Started by Spewing, January 31, 2009, 03:02:14 AM
dankie
Quote from: TheBuzz on February 10, 2009, 06:31:49 PM
20 ohms per foot? Wow Dankie and you think you ar using the same wire as Stan? Stan claimed .0043 ohms per foot in his notes.
Next, if you knew even the most basic things about magnetics, you would know that a bifilar coil is non inductive.
Next, the magneto provided the high voltage to the injector. If you looked at that blue print of the injector, read the patent and notes, you would see one end of the coil is supposedly switched to ground.
Now let's at a coil where Meyer actually used the stainless wire which isn't very gifted (like you) when it comes to holding onto its electrons.
The two toroid coils with the stainless wound THROUGH THE CENTER just like the accelerator I described. The cross hatch causes electron collisions just like the bifilar coil which causes them to fling off. Meyer should have called it a negative resistance coil.
http://jlnlabs.online.fr/cnr/cnrexp1.htm
Fuck you John Bositic, that was my joke. Try forming your own thoughts for a change you spook fag.
http://wiretron.com/
Download the wire software on that site . If you had just a bit of common sense you would realise that this was a typo , as we have pointed out many times ...
You can see that even pure silver wire of 38 awg  (.004) has 0.59 ohm per foot . Obviously that is totally illogical and is a typo ...
EDIT that is just 600% out of spec with something physically possible with ambient temperature
Not only is this a totally obvious typo , it is also ridiculous to say that since Stan says stainless steel wire is used  , there is no such thing as stainless steel wire with anything under 15 ohms per foot for 34 AWG , w/e that alloy may be ... Not a very logical person are you ?
johnbostick
Who thought I was talking about Buzz?
This I quote,
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance ---- that principle is contempt prior to investigation."       ------ HERBERT SPENCER --------
Just because you don’t see it doesn’t mean it’s not real.
dankie
dankie
Quote from: dankie on February 06, 2009, 01:33:08 PM
TheBuzz is not helping us , he is just trying to make us second guess ourselves , he wants us to go hunting for right wavelenghts and U.V lasers ...
Yes I like to fight , I am undefeated so far  ... You think TheBuzz is tough lol ? I eat TheBuzz for lunch ... Think you can argument with me TheBuzz ?  When I am done with you even your adoring fan will abandon you ...
Lol where is grumpy ? Been a few days ...
You remember this The_Buzz ?  I warned you what would happen if you started argumenting with me .
Its like when you go to court , its always harder to tell lies and get away with it than to just tell the truth .
You start getting confused in your own lies at some point .
dankie
Quote from: TheBuzz on February 10, 2009, 07:10:26 PM
Actually there are steel and composite copper wires that prove that wrong statement wrong.
Typo? Yeah, there are more than a few typos in Meyer's notes and explanations for the process. Meyer was a pathological liar. He would lie about what he had for breakfast to avoid telling the truth.
Now about that bifilar primary winding on the VIC Dankie, since we have electricity going both directions with what amounts to a high voltage short on one end, how would it be possible for that coil to step up voltage. Have you ever wound a single transformer? Or even hundreds or thousands of them?
It is impossible for that coil to generate high voltage. Why would Meyer switch the secondary of the transformer and what transistor would you be using to switch tens of thousands of volts dip ship.
Would you mind discussing the technical aspects of what you are claiming without all the childish insults or at least mix the two? So far, you are devoid of anything but cut and paste and you don't what you are cutting and pasting.
We will save this for the future so you cant edit it out
