HydroMeyers Vic
Started by Spewing, January 31, 2009, 03:02:14 AM
ramset
All
This is a lot of work [so what!!!,the payoff is big!!]
While you wait
THIS GUY IS THE REAL DEAL, A TRUE BLUE OPEN SOURCE HERO
                                             GROUNDLOOP
And he has something going on !!
       Here .......   http://www.overunity.com/index.php?topic=6519.250
                       The kind of man you would trust with your life!!!
    Chet
More later
Thanks Grandma
ramset
More from the Buzz
The VIC is the ground side of the circuit. The water mixed with ionized radicals is the positive side of the circuit. Da!
The highest voltage mosfet I own is around 900 volts. Without all that stainless RESISTIVE wire between the charged water and the mosfet you will smoke the mosfets.
The air/gas processor is in the back end of the injector in later model. Under the plastic cover by the spark plug wire is a filter and needle valve where the air goes in through an aspirator, gets radicalized by the gas gun (ozone), goes down through the center insulated tube / electrode, enters the tiny little resonant cavities and mixes with the water, hits the spray grills and "FRACTURES" hits gets further compressed in the taper resonant cavity where it hits the two ground electrodes and explodes.
The two electrodes are connected to the vic coil which is made of stainless so they don't donate electrons back to the water (LIMIT CURRENT FLOW) the SS coil does resonate and then gets switched to ground through the mosfets. The chokes limit current going to the mosfets.
The connector that controls the mosfets is on the side (Three contacts) The center contact is positive which drives the LED lasers in the gas gun and this process all happens in a fraction of a second.
Water going to the injector is at 120PSI.
That is how it  works. I built it a year ago with the plasma electrolysis which has been on my site ever since. Only one person to my knowledge ever had the fucking brains to put the plasma tube before the cell to produce those radical (O3 - O4) atoms  - me. It is called bond cleaving in general and .
Oh yeah, if you want to draw energy from the circuit, connect it to that outer bifilar coil. I am pretty sure that connected to the resonant cavity boxes on the side which should contain a cap and a diode which is charged opposite the water so the water and gas exchange electrons. (bond cleaving)
More later
Chet
Thanks Grandma
Outlawstc
ramsat,
can you post your own work and stop being a little grunt messenger bringing information from the buzz? so if you are getting info from buzz and sharing it, what does he go by these days on the forum? also why is the buzz using stainless.. i thought he mad a big deal out of dankies stainless saying its not nessasary?
outlawsrc
its not the fuzz you gotta worry about in these neck of the woods, its thebuzz
ramset
Outlaw
This info was posted on this Forum, by the Buzz
I realize your animosity towards theBuzz [well deserved ]
He did not like Dankies claims of the wire being the'' ONLY'' wire
Before you came to this thread, the Buzz said he left it ALL here {Grumpy agreed]
         I will continue to search all post's, by any one anywhere that are relevant
Several members lost their homes [to the banks]just today [in this VERY small slice of the world]
More to come
Chet
Thanks Grandma
Outlawstc
we have read this whole thread ramset...  you keep bringing up past discussion like a ghost of the buzz presents, there is no  useful information you posted of buzz's past post.. we are on the right path.. we have seen pictures of the REAL stain meyer 6-1.. we know what we are going for.. and we are sharing it with everyone... we bring up present date questions. you slur them up with the past,, you get my drift? we have read it ramset.. by you back tracking to catch up you dont need to post it again.. any one that is interested can go back through the thread and read it,, just because it was posted in the past dont mean its not still OPEN SOURCE.. . bring some relativity to the plate or just watch the thread.
