HydroMeyers Vic
Started by Spewing, January 31, 2009, 03:02:14 AM
Spewing
Quote from: Dave45 on March 13, 2009, 12:50:19 AM
So if I got this right Spewing your trying to run hho to the injector instead of water, a thought I had if you separate the oxygen and hydrogen at the wfc run the oxygen through the gas processor instead of ambient air and then recombine them wouldn't this limit the electrons in the cylinder for your application.
Also this might help with the heater application or the carburetor.
Dave, I am not trying to do anything that has not already been done. Hear me again.
These guys that is running their generators on 7 liters a min. "Those guy's are already doing it."
FOR EXAMPLE. ScareCrow on youtube uses 7 liters to run his engine. This means that ScareCrow uses 29.4 cc's of gas every second to his engine. Scarecrow also is wasting 87.2 cc's per second all because he does not have an injector.
I AM NOT DOING ANYTHING SCARECROW DID NOT DO, The only difference is i will not be wasting gas like he is doing. By the way, scarecrow is a cool dude.
Now, On the injector controll issue. I found a way to controll the injector on almost any go kart engine, meaning anyone here can make this part in 5 min's max! It is so easy to make a cave man can do it LOL.
You must be clever.... Now all thats needed is the injector, and the timing between the injector and valve switch.
Spewing
Spewing
Outlawstc
spewing,
this book should be very resourceful for making your linear position sensor.. check it out
http://books.google.com/books?id=0SwbWS64c7UC&printsec=frontcover&source=gbs_summary_r&cad=0
outlawstc
its not the fuzz you gotta worry about in these neck of the woods, its thebuzz
Room3327
@Dave45,
   I think that is an outstanding idea for seperating Hydrogen and oxygen, have you tried it?
