Real OU-Effect to Share with everyone!!!
Started by Magnethos, February 02, 2009, 08:37:03 PM
0 Members and 18 Guests are viewing this topic.
Magnethos
All this entire experiment is described in the book "The Final Secret of Free Energy" of T.Bearden.
But we've mixed the theory of that book with the experiment of NRGfromthevacuum, and the results are different (because the experiments are different).
The original theory (book's theory), is easy. We need to know only the relaxation time of the material. Once we know the relaxation time, then we need to Pulse DC electricity below the relaxation time. In other words, we need to pulse DC faster than the relaxation time. Here the COP doesn't exists because we aren't drawing power from the battery. We're only drawing pure potential (voltage). Then, we can measure the output power from the collector (Capacitors). But I repeat: we aren't drawing power from the source, for that reason the COP doesn't exists here. We only need to dope a conductor because all pure materials have a very fast relaxation time (in order of 10 ^ -14 secs). If we dope a conductor maybe we can get a relaxation time of 10 ^ -8 and then we would be able to work with that time. Maybe using aluminum and tin as a dope material, we will have a good wire. One option is to use Fe-Al wire, but it's difficult to melt wire at home, so maybe we can use the correct amounts of Aluminum and Tin to get a good wire.
The only thing I need to know is how to calculate the relaxation time in Alloys. I know how to calculate it in pure metals, but not in alloys. When I know how to calculate it, then the only thing we need to do is to build a frequency generator and a little of wire. Then we will have an unlimited source of energy.
Of course, I'm looking for the formula to calculate the relaxation time. But If anyone knows how to calculate it in alloys, we will have the final answer. Only a formula and I will show you how to get a free energy device.
PS: I hope someone will know the answer because we want to get a solution and don't forget this post in the unlimited bytes of the net.
Frederic2k1
QuoteAll this entire experiment is described in the book "The Final Secret of Free Energy" of T.Bearden.
Not only that, my dear. This whole thing is the secret of tesla.
Tesla discovered that the faster he can switch and the more abrupt he open his "switch" after closing (before real current saturates the wire) the more aetheric-radient scalar waves radiate of his wire and opens a fully new "kind" of electricity, the so called cold-electricity.
And with this kind of electricity, Tesla was given the ability to create heavy currents and very high voltage, directly from the aether.
Nearly all tesla patents are non conventionel electrical systems, but devices to control cold-electricity.
After the discovering of this scalar waves, tesla tried to build more and more devices, witch can more and more shorten the switch sequence.
Look at the magnetically quenched spark gap. With this device tesla was able to create sudden high-voltage discharges under the microsecond-range.
There is no need for semi-conductors, in contrast semi-conductor will never be able to create disruptive discharges because of leak current !
Magnethos
I said I read it in the Bearden's book, but I don't know if there is the same theory in other books. As you said, Tesla also explored this phenomenon.
The problem here is the extremely fast switching that we need to achieve if we want to use copper as wire. There are 2 solutions:
1. Create a very very fast automatic switch (around 1 ^ 10 -14 secs)
2. Create an alloy with a higher relaxation time
Do you know what kind of wire Tesla used?
As you know, batteries are free energy generators themselves. The problem is we don't know how to use them correctly. When we draw current, we're closing the "magic gate" that batteries need to tap energy from the vacuum. But batteries must be used to get pure potential (scalar) energy. I don't know why we get Transverse energy when we use a battery in the common way, instead of getting logitudinal potential.
Frederic2k1
Quote1. Create a very very fast automatic switch (around 1 ^ 10 -14  secs)
1. is easy, as described above, the adjustable magnetically quenchend spark gap will solve this problem.
2. No need for it. High-inductive coils increases the saturation-time. This is also the reason, that Nrg does use such a coil. Without the coil, he will never be able to switch under the range of relaxation time manually...
Even Tesla had no source of special alloys.
Please read my theorie that all real overunity-devices need a spark gap to create energy of the "wheelwork of nature" - the aether.
It is postet at the tpu-forum: http://www.overunity.com/index.php?topic=4100.0
Magnethos
Quote from: Frederic2k1 on February 25, 2009, 02:06:52 PM
QuoteExplain me more about that, because that extremely fast switching time it's difficult to replicate by me.
QuoteI don't know how to calculate the relaxation time using variables as the high-inductive coils. I only know to calculate the relaxation time in pure metals.
QuoteOf course, I will read it now
