Can it be this simple? Magnetic Viscosity (lag) is the key?
Started by mikestocks2006, February 05, 2009, 12:22:53 PM
ChileanOne
Boys, you are a tad little behind.
From http://www.steorn.com/orbo/technology/
How Orbo Works
Orbo is based upon time variant magnetic interactions, i.e. magnetic interactions whose efficiency varies as a function of transaction timeframes.
It is this variation of energy exchanged as a function of transaction time frame that lies at the heart of Orbo technology, and its ability to contravene the principle of the conservation of energy. Why? Conservation of energy requires that the total energy exchanged using interactions are invariant in time. This principle of time invariance is enshrined in Noether’s Theorem.
The time variant nature of Orbo interactions can be engineered using two basic techniques. The first technique utilizes a method of controlling the response time of magnetic materials to make them time variant. This is achieved by controlling the MH position of materials during permanent magnetic interactions.
The second technique decouples the Counter Electromotive Force (CEMF) from torque for electromagnet interactions. This decoupling of CEMF allows time variant magnetic interactions in electromagnetic systems.
Orbo 1.0, the first commercial release of our platform technology, is based upon our electromagnetic implementation. Orbo 1.0 will be made available initially under license to 300 engineering companies and to the wider product development community later during the course of 2009.
BEP
Wow!
Steorn invented power factor and real vs. apparent power? I suppose soon every household will have two Orbos in every pot. I'll make my pot ready!
sparks
Lenz law states that the voltage in the coil will be such that the resulting coil current will create a magnetic field that opposes the original magnetic field change.  Now how to delay the coil current.   Make the coil with alot of inertia in it.   Lots and lots of electrons to get moving before any current flows.  Lots of inertia to overcome before the current flows.   But once it flows it will flow for a longer period of time.  Until the electron inertia is altered by the load.  So say we have an input winding and the current is choked and all the energy goes into magnetic density changes in the core.  The output winding experiences the same magnetic core density change but is of high inertial value and the current is delayed while the electrons are taking their sweet ass time accelerating.   Finally the current flows in the secondary but the input voltage has already been switched.   The current flows in the secondary and desaturates the core out of phase with the primary input.  The amps are choked or impeded in the primary winding but not the voltage drop effect on the core.  The only current flowing is in the secondary which desaturates the core.
   If two output windings are used and they are put slightly out of phase.  A highfrequency high voltage pulse of many orders of energy greater than the input pulse are attainable.
   Electrons are very very light so this is not going to happen at a low frequency unless you go with huge amounts of mass.  Attention to which way a free electron has it's inertia invested in plus external electric, magnetic, and gravitational fields all come into play.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
BEP
Sparks
In your Lenz law statement just make that coil a single layer flat spiral. The generated mag field is 90 out instead of 180.
PaulLowrance
Magnetic viscosity is half the key. The other half is a change in *effective* permeability, which can be accomplished by solid-state or mechanical means. I've been documenting this online since early 2005, way before Steorn announced anything to do with "free energy."
Here's last weeks big news update in my research:
http://greenselfreliantenergy.com/forum/index.php?topic=285.0
PL
