ENERGY AMPLIFICATION
0 Members and 72 Guests are viewing this topic.
Magluvin
Ok, some measurements.
the 35 turn secondary is .11 ohm
Each of the primary windings are 1.37  1.39 and 1.40 ohm
Capacitance measured between primary windings is 2.2nf, between any of the 3 as they were wound together.
The difference in the primary ohms may just be lead connections with the meter leads, as they should all be very close in length being wound at the same time. During the 8th layer, some of the turns dug into the 7th layer. Maybe 7 wasnt as tight as it should be, maybe the bobbin expanded a bit from the layers of wire pushing outwards at the end. But the winding neatness was just a bit bumpy after layer 10.
So there could have been a chance that one of the wires is a bit longer than another by the time 10 layers were finished.
Measuring the capacitance the bifi was odd. Working with just 2 windings, and one of the meters probes connected to one winding, and the other probe to the other winding.
If the probes are on the ends of the bifi at the beginning of the winding, the meter reads 0.0nf .
But if you move one of the leads to the other end of the same winding it was connected to, I get 2.2nf. I tried it with all 3 windings and it was consistent.
And for giggles the primary to secondary capacitance is .2nf.
Meter used  Wavetek 2030
Inductance meter is on its way.
Mags
TEKTRON
I think Bob's poem inspired me. Time to get out of the deep depression I've been in for a very long time! I'm clearing off the work bench (junk collector) and finish what I started almost 2 years ago. Mags, I don't want to deter you from what you are doing. I'll wait to tell, till your done building and testing your current vision.  8)
Thanks guys ;) ;D <-- ME HAPPY
Magluvin
Hey Tech
No Problem. Show your project.  The more the better.  ;]
Mags
TEKTRON
Quote from: Magluvin on February 17, 2012, 12:32:40 AM
Hey Tech
Mags
not now I'm in cleaning mode :P BFN ;D
one_christian_warrior
how about energy multiplucation
where you have two equal voltage motors
one is DC for input
which has a large pulley attached to it
the second motor is AC
on a much smaller pulley
this way your driver motor only turns a few times
while your output motor spins hundreds of times
you get a multiple of power out
compared to the power you put in
you run your output motor, (or multiple motors)
through a full wave bridge rectifier and voltage regulator
I proved this works
with my electric wheelchair
gaining 20 feet more distance up a steep hill
every time I drove up the hill fast
and then drove back down the hill slow
(I had to set my chair to max torq=1st gear and max speed=10th gear)
http://free-energy.yolasite.com/
