ENERGY AMPLIFICATION
0 Members and 96 Guests are viewing this topic.
Gyula, yes,this publication I meant. Thanks a lot to free me from long searching.
I was  really surprised searching for this publication how good even under this family name 100 years before people made invention,also shocking one :   Applicant:Patten Object: Insekts-Exterminator   ;) 1913 ;) Arnieeeeeeee !
For each problem +/- one solution,or 2,3,......  .
I hope in Hungary is sommer 2 ?
Happy Sun-day and my greeting from ex-Galaecia
        CdL
gyulasun
Lanca, thanks for the kind reply.
Yes many many things have been already known (invented) in the past lifetimes, during the centuries.  This Patten patent is a clever implemantation of driving an electromagnet from AC current, to prevent the magnetic poles from changing as per the AC current would dictate and this was a novel way of doing it in the era when the DC 'world' was still alive and electromagnets were operated from DC sources.
I would like to understand what prompted you to mention this double coil electromagnet here, in connection with Dave45's postings?  Because Dave described two trifilar coil setup and we are here to figure out extra energy and unfortunately I fail to connect your dots...  could you hint some explanations?
The mechanical transmission gear with the 4 motor's torque summed into a single shaft is also a good solution, it can reduce power consumption but again I fail to see any other advantage. OF course, reduced power input is always a benefit, I agree.
Greetings,
Gyula
PS: we have hot weather with 33-34°C and it is forecast for next week too.
Magluvin
Hey Dave
In the Utkin pdf's he seems to imply that having these opposing, oppositely wound coils in series and facing each other like you show on the previous page, that once you start the process in this config, that the oscillations build on their own and a spark gap is necessary to keep it from going to high on its own. :o
I have some pvc, wire and some 2.5in size flex loom stuff. The flex loom is like say plastic(no spiral wire, just plastic) vacuum cleaner hose(ribbed) split along the length. Ill use it to make consistent spacing between windings, like Don Smith coils.
Ive been meaning to try this for some time. Was just busy and more interested in what I have been doing.
Your drawing is not a Don Smith coil really, unless he has done it your way and I have not seen it, with the trifi windings. But the opposing coil concept is what he used.
Im going with your drawing first. I have no clue as to wire size or number of turns, so I will just wing it, equal on both sides.
Ok, gotta go get Bebe(my kitty) some food. If I just say food or hungry right now, she will MEEEEEEOOOOWWWW.  ;]  She has plenty of hard food and snacks, but she finished her soft food last night.  I try to give her a balance. And shrimp a few nights a week. I can hardly cut them up for her as she will not stop rubbing and bumping my arm waiting for me to finish.  I would give them to her whole, but she will take them elsewhere 1 at a time. I dont want that. ;]
MaGs
Tito L. Oracion
Quote from: ramset on August 19, 2012, 09:19:07 AM
Dave
Quote:
My dear friends
I seek neither fame or fortune, I want to patent nothing
I want to help the poor
God is in control
dave
I am a poor man by American standards but I dont need or want much in this world, lay up your treasures in Heaven.
end quote;
Dave, this time it must be different Not "fame and fortune" like some people say.
But to "do the right thing"   ............Just as you have said above!
God Bless you Brother!! and all the others here that have helped along the way!!
Thx Chet
PS Teets ,you whackadoodle .....its time to run the fridge on the watch battery !:.}
you just asked dave, he will help you.  ;)
:D
Tito L. Oracion
Quote from: lancaIV on August 19, 2012, 09:23:48 AM
Tito,in Germany there is an Org for Basicsresearch "Grundlagenforschung" : Max-Planck-Institute and
there is an Org for applied basics "Angewandte Forschung": Fraunhofer-Institutsgruppe
and this here is portuguese "applied basics": Dave45 schema -double coiled e-magnets-concluded in a Rotor
,partial awarded,later monopol-right -lost caused -no pagamento-dos custos annuales( premios ? :-\ ),
                                        They had only for a short moment the monopol in their hands !
                      I thought that this technician is the right guide to translate my thinking ::) 8) ;) :
                                                    come baby,let it rock and roll'in  :o
                                     Senhôr Ferreira 'jorge' converted later common to own intentions ;D
http://worldwide.espacenet.com/searchResults?PA=envez&DB=EPODOC&locale=en_EP&ST=advanced&compact=false
now open source
One other scientist Dr.Pavel Imris,Csc. with him I worked together-the project-operational part was mine-
( not technical/physical : in the real world outside this ecran I do not like either maths nor physic formulas,
to complicated and abstract :o ::) :) ) optimized the capacitive winding concept ,synthesizing an PM,
making it the-permant electric  magnet- with flexible forcepotential for variable speed/variable input et cet.
for motor and rotative alternators open source
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=20110609&CC=DE&NR=112009002191A5&KC=A5
p.s.: the mechanical  way to explain and demonstrate the monopolar quenching from the  force momentum is here : http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19951107&CC=US&NR=5463914A&KC=A
if there is no more doubt there is no (great) evolution barrier :
PSI-Scientist C.G.Jung: Motiv-ation time-forcing factor:10 times                   Mariendorf ,Cz ;Human being analysis
Still don't get it huh ?  :o
well, dave is much better than you, he is the only person here who grasp what i wan n mean a say.  ;D  lol
your not poor sorry dave won't help you  ;D  lol
;D
