ENERGY AMPLIFICATION
0 Members and 120 Guests are viewing this topic.
pix
Hi,
No probem.
I was thinking about the same circuit with antenna and properly chosen LC value and a spark gap just like in Tesla setup.
Then as follows:
1.Small condenser charges up to high voltage from signal received in antenna.
2.Then condenser "fires" across a spark gap  to the primary of transformer. Current amplification takes place across spark gap ( electron avalanche).
Wht do you think?
Condenser needs to be really small,but high voltage- then rate at which it "fires" depends from LC values and can be adjusted for frequency needed.
I see a resonant LC circuir with antena as ambiient "energy sink".
Peace.
pix
Tito L. Oracion
 :o
High Voltage, high frequency, resonance?, in my first quest about searching free energy, i thought they are, but absolutely NOT!
It is actually the momentum, moment particle and the method of accumulation of energy in a lot of coil is the secret, and tesla say it by means of an iceball.
if HV,Hf, and R is the secret, then i think we are not paying electricity a long time ago.
its like a worm gaining a little distance and after a while it gains a lot of distance, and the difference is TIME.  ;)
HOPE YOU GET IT
YUNG BANG PARANG UTOT NA MABILIS KUMALAT  ;D  LOL HAHAHAHAHHAHAHAHAHAHAHAHAHAA
ramset
ang iyong puso ay isang iceball   :P
marahil ama ay matunaw iyong nagyeyelo puso bukas-makalaw
Pagpalain kayo ng Diyos aking kapatid na lalaki, ako ang sa aking panalangin
HHMMmmmmmmm
I think I like this Bilingual stuff.......
Thx
Chet
Thanks Grandma
Neo-X
pix : Hi,
No probem.
Then as follows:
Wht do you think? Condenser needs to be really
can be adjusted for
frequency needed. I see a resonant LC circuir
"energy sink".
Peace.
pix
--End of Quote--
Yeah that was the original tesla's design and if im not mistaken that was the circuit he used on his pierce arrow electric car. Mine is much simpler than that no need for diode and spark gap. All you need is tune up the primary coil and capacitor to the strongest frequency available in your area to get the largest output in the secondary. The one end of the primary coil must connected to a long copper rod buried on the ground and the other end connected to a very long vertical antenna. But i dont know which on two circuit are much better.
Neo-X
@tito
I dont understand this part:
How can tesla say it by means of iceball .. Lol :D
@ramset
iceball   :P
Lol.. Hahahahaha! You can speak tagalog?
