ENERGY AMPLIFICATION
0 Members and 186 Guests are viewing this topic.
totoalas
Thnx  Gyula
made my work easier ....
with e cores    less turns
either use welding rods as my core around one  inch total diameter and 12 inches long...... ( only the steel are used / powder scraped already)
Irondmax in youtube had some good video on the Lawson circuit
In my latest circuit  Slayer Transistor mod ( Slayer Booster 2dmax  YT   imtotob)  where I have a c and cw coils in one tube  pulsed by one primary coil...12 v dc
My observation , no induction on the side or near the coils which normally occur in a Slayer circuit..Lower ends of the coils are connected to base and ground of the transistor... they are all concentrated on the tip of the upper coil wires
The output coils from the c and cw coils can light dc led lamps but not ac fluoro lamps      strange.......
The other circuit I used the fly swatter circuit with spark gap from a relay and using earth ground   ... there is a 1 cm arc in the wires and coils as well   with only 5 v dc supply the energy is scattered  ,,,,,,,
So My experiment with tito 's circuit will probably start from these two pulsing circuit
gud night
totoalas :)
gyulasun
Hi DimaWari,
Yes, if we attached a oscilloscope across the capacitor in this setup, we would surely see an sawtooth waveform, its amplitude would depend greatly on the size of load across the output coil. Hopefully when we suppose a constant load, the lower value of the sawtooth wave may be (say) 12V (the initial charge fed in at first start) and the peak value of the sawtooth wave may be (say) 30V.
Gyula
Quote from: DimaWari on February 03, 2013, 01:30:11 PM
Tnx Gyula,
Its my mistake. I thought its the same with tesla electrical transformer. But here were talking about capacitor discharge while tesla use pure sine wave. And Its more like of a sawtooth wave when we dump the of capacitor charge into a coil right?
crazycut06
Quote from: gyulasun on February 03, 2013, 10:02:39 AM
Hi Crazycut06,
Yes, I also think that basically the pingpong toy principle and that of the shown patent circuit is similar, there are two differences:
Tesla used an outside energy source, connected to lines A and B  and Tito claimes to use  precharged capacitors, the other difference is that Tesla did not show any feedback path from output to input while Tito has described his circuit with feedback, 'suggesting' that the two caps can be maintained in a charged up state while hopefully some useful output power can also be had.
rgds, Gyula
Yes you are correct about that, Tito always mention correct combination of parts, if done right, maybe, maintaining the caps charged is posible.
Cc
totoalas
Quote from: crazycut06 on February 03, 2013, 07:10:12 PM
Cc
Add to that  laserhacker.com uses supercaps  maxwell 26000 uf  2.7 v eliminating the 12 v battery in his car
crazycut06
Quote from: totoalas on February 03, 2013, 08:20:45 PM
I think that the capacity is too big for this initial circuit, if we can make this circuit run as per Tito's description, maybe we can upsize it for those supercaps for more power.... :o
Cc
