ENERGY AMPLIFICATION
0 Members and 42 Guests are viewing this topic.
Tito L. Oracion
Quote from: forest on June 24, 2013, 10:49:18 AM
Tito, one question if you mind. Which one coil need to be ordinary wound ? primary or secondary ? I'm stuck with electronics , have to find a way to the fastest possible charge of capacitor (low ESR) aka make & break part I  ;)  The whole concept is clear and simple and I see it for over 2 years now but actual implementation still lags....and I'm not sure if this OU is by nature law we didn't understood or simply there is the inflow of external energy on resonance.....this is bothering me.
Kinda very easy idea, guys if you realize that the only real method of rising amperage is by fast capacitor discharge , exactly like Tesla mentioned.
Well, in primary it is best to do it in thick awg bifi and secondary is arbitrary and they were done in one purpose.
Ya, you try to connect and disconnect the caps, i mean very fast and it will not discharge all the juice. if you can make many make and break. then that's it. all you need then is how will you make your coil very efficient. isn't that simple guys?. its a piece of cake.  ;)
Its like answering how many make/break you can do in just one fully charge caps?  ;) 8)
ok!, let me illustrate it this way, let say for example you have your oxygen and there is only 1 minute to use it and will take you one hour to get you up from the bottom of the sea, then what will you do. i think that is self explanatory.  ;D
HOW LONG CAN YOU HOLD YOUR BREATHE? ;D , WELL ME CAN DO IT IN 2- 3 MINUTES AND THAT IS MY MAXIMUM!  ;D
LET ME HEAR YOUR SOLUTION AND I'LL TELL YOU MINE.  ;) 8)
etits  ;D
forest
Tito
I very much like you , so I will be clear what I have in my mind for more then 3 years now , and I know I can't be mistaken as the whole concept , only the implementation is still not working due to my bad ability to construct such devices (well, any devices :( )
This is all about reactive power or rather the resonant power.Background (as I understood it) : If you have AC circuit the reactive power is the resonant condition which occur sometimes when elements match LC tank circuit (like wire inductance and capacitance) - in normal AC reactive power goes back to power source heating transmission lines with harmonics (maybe also intermodulation of waves ?) . Surely we have to eliminate it ...
So we have to charge capacitor bank and discharge into a coil having low resistance to create tank circuit of high Q factor so the reactive power inside will be huge while there is no connection to escape , because power source would be disconnected ! (or capacitor would be a power source)
Yes, famous Tom Bearden picture of degenerative semiconductor !
Like you said : take one breath and hold on.
Then ou is simply to have a second coil near such tank circuit , which will tap power converting reactive into active.
I hope we would construct Hubbard generator together oneday soon, that's my dream. What do you think about it ? I like this idea!
btw this concept has a huge flaw which is the make & break controller itself as you know. I bet we can eliminate it !!!!! However first I must learn how to walk before run, and I have no experience in electronics like you (probably) have.
I planned to patent my device and maybe it will happen but not soon, I still believe you can patent device but not the concept, while in patent the concept should be clearly stated. It is not so because every devices work on the same concept already patented before WWII or ealier.
One thing is clear : energy comes out as always from magnetic field and Faraday law of induction.
But there is more about this which I'm not yet ready to discuss....Just think about the lenz-free transformer applied to 50Hz AC source. Is there the energy transfer from primary to secondary or a copy of energy created on secondary ? <---- BIG and WEIRD QUESTION
No matter if there is energy transfer or "something else" such lenz-free transformer is still only 100% efficient without resonant circuits on primary and/or secondary - think about it! think hard !
I still can't find the explanation why things when hit start to vibrate, and I'm still delightfully surprised by this phenomena which joins gravity and electromagnetism into one realm
totoalas
etits  ;D
aS Ryzza said   Better die struggling than thinking on how to breath which is next to impossible.....
Think like a fish and swim like a fish   ......  do you think the same as what im thinking     lol
Tito L. Oracion
 ;D ;D ;D ;D ;D ;D
ok here is my solution: well, obviously you need to chunk the oxygen for efficiently usage ok?, good!, and
Many times i carry big plastic bag with me when i take diving  then i have to fill that plastic bag first to lift me up faster and that's automatic, and in that sense
i will not anymore use lot of effort to use my feet and hands for feedling, and will just use them for control right.   8)   :)   ;)
its automatic jetmatic success!!!!!! 8)   bwa hhahhahahahahh heehhehhh heeihh  ;D
got that? simply simple just need some common sense right? but really effective way.  ;)  lol
just relax and see a movie  till you get up ok  ;D ;D ;D  hahahhahahahhoooooouuuiiiiihhhh  ;D ;D ;D
Now!, will you still ask me if it will make you float faster, i mean very fast?  :-\ :o :o   ;D ;D ;D
Magluvin
