ENERGY AMPLIFICATION
0 Members and 65 Guests are viewing this topic.
Cadman
Now the creative juices are starting to flow!
Ha, and silly me thought I had an original idea about that diode in the ground wire :) Thanks for all the links guys!
Let me tell you all a true story that may be relevant here. Before I even knew that forums such as this one existed I built a free energy device and discovered free electricity. Entirely by accident. True, no BS.
Years ago, in the springtime, I was having trouble with my TV reception and went to check the antenna connections.
Now I live out in the country and my antenna is one of those old aluminum ones from Radio Shack that looks like two feathers of an arrow about 6 feet long, and it's mounted on top of a 20 foot iron pipe, which in turn is attached to an old 12 inch diameter cast iron pulley, and this pulley is buried a few inches into the ground. An ordinary coax cable runs from the antenna through a couple of stand offs, then into the house at about 3 feet off the ground. That coax is too long and about a dozen feet of it is coiled up on the floor behind the TV stand then connected to a splitter to run to a couple of other rooms. Now the pipe and pulley was built by an ancestor and it is painted with several layers, and that paint is surely lead based. There is also a good chance the pipe is a galvanized black iron water pipe.
So I went to check the connection between the coax and the antenna, maybe the upper connection was broken. Not wishing to get up that high to the antenna I decided to check continuity at the living room end of the coax. After unplugging the TV and disconnecting the antenna coax from the splitter I carelessly touched the outer and inner points of the coax with my fingers end and received a very surprising shock! It was similar to touching a 9 volt battery to your tongue. At first I thought I had the wrong coax and that a TV from the bedroom must be feeding current. Nope. It was definitely the one from the outside antenna. My meter measured 51 volts DC coming off the antenna coax! What the heck?? I checked that current several times over a few days and it was always there right at 50 volts. The antenna is a good 50 feet from the power lines and no other lines are in the area. Months later, in dry weather, and after digital TV was mandated by the government, there was no current there.
So my shocking experience set me on a search for a way to use this free energy and here I am. A couple of the first things I learned that fit my situation was Tesla's statement regarding the potential that exists between the ground and higher elevations. Then I was surprised to read that Tesla invented the coax cable and that it was a capacitor. Also that electrical devices emit RF and magnetic fields, and we are bathed in microwaves no matter where we are.
So you see, I already know there is in fact such a thing as free energy, and that it had been discovered long ago.
So how is this story relevant? Free energy is already out there, in more than one form, and my antenna by itself furnished 50 volts. All we have to do is collect it, channel it into our device and amplify it. We might even want collect what our device radiates and recycle it, eh?
Tito L. Oracion
Quote from: a.king21 on January 24, 2014, 03:43:44 AM
Question for Tito:
Do your devices all have a ground wire?
No. Why? what is that question for buddy?  :-\
of course it always depends on the design you are doing.
Like for example the receiver can use earth ground or use the negative pole of the battery to use as ground or we can use diode as a way out to air as ground. there are lots of option actually. 8)
sorry i'll rest for awhile cannot answer anymore. :)
otits :-*
[size=78%] [/size]
a.king21
Quote from: Tito L. Oracion on January 25, 2014, 06:33:25 AM
otits :-*
[size=78%] [/size]
Well, it was because you mentioned Tesla's receiver, which has a ground attached.
Thanks for the tips.
These are very much  appreciated by us.
Cadman
Just for clarity,
Tesla's wireless receiver, is this the one we are referring to?
Tesla patent 645576
DilJalaay
Hello Tito Sir,
Are you going to delete your posts or not, as i am reading your old posts, and i am v v very much close to your secrets, then i will tongue you :P  (just joking sir). You are my much favorite teacher sir, i love your way of teaching, and much respecting you.
My questions, are you still using battery as a source for your device?
2nd can we make an other kick on a kick? double kick on single input?
Is your 1st schematic is still valid or workable or you have an other better method? (attached)
Regards,
D.J
